Serial Communication & Adafruit IO
by JoseeMallah on Fri Jan 08, 2021 5:33 am
Hello everyone!
I am using an Arduino UNO to get analog readings from 2 sensors. Then, I am sending the product (*) of these 2 values to a NodeMCU via serial communication. The value is received correctly: when I use
Serial.write(Serial.read())
correct values are displayed. However, when I move the value received to a variable then print it:
x = Serial.read()
Serial.println(x)
different (wrong) values are shown. And these same wrong values are uploaded to Adafruit IO.
So, does anyone know what's happening? Any format or data size differences? Why am I obtaining wrong values? And how to get the correct ones?
Thank you
JoseeMallah
Re: Serial Communication & Adafruit IO
by dastels on Fri Jan 08, 2021 11:11 am
What language are you coding in and what is the type of x? There is probably some incorrect casting/coercion happening.
dastels
by JoseeMallah on Sun Jan 10, 2021 11:50 am
Yes right thank you, I had to use parseFloat().
JoseeMallah
