24hour format in Adafruit IO
by thoru on Sun Jan 17, 2021 12:08 am
Starting to look at Adafruit IO, so new to all this.
I see only am/pm format everywhere on the webpage. is it possible to change it to 24 hour format instead?
thoru
Re: 24hour format in Adafruit IO
by mikeysklar on Mon Jan 18, 2021 5:40 pm
@thoru,
Are you trying to adjust the time display on the adafruit.io website or on your client hardware? I see a few different ways to set it on the client side. One example is how we do it on the magtag.
USE_AMPM_TIME = True
https://learn.adafruit.com/magtag-cat-f ... -fed-clock
A little more on time options here:
https://io.adafruit.com/api/docs/mqtt.html#time-topics
mikeysklar
by thoru on Tue Jan 19, 2021 12:56 am
I'm viewing the timestamp in the website.
good to know about the client :) do you know how to also affect the website?
thoru
by mikeysklar on Tue Jan 19, 2021 6:16 pm
Does adding this to your adafruit.io URL convert the time to 24 hour?
/your-24-hour-page
mikeysklar
by brubell on Wed Jan 20, 2021 11:24 am
thoru wrote:I'm viewing the timestamp in the website.
Where on the website do you want to see 24hr time? Gauges/blocks?
brubell
by thoru on Wed Jan 20, 2021 4:55 pm
As one that is accustomed to 24 hour format I would like to have that everywhere I see pm/am format :p so a option on the account to switch between the time-formats would be great. In Adafruit IO I see it on the timestamps of feeds. And in dashboard on every block timestamp (mouse over). line charts, stream a feed. and probably other places I haven't experimented with yet.
thoru
by thoru on Sun Feb 14, 2021 3:40 pm
jonathan435 wrote:I am always a fan of AM PM format.
jupp. I completely understand that. but where I live we use 24 hour format. not the pm/am. so when I use software or whatever and there is not an option to switch I get frustrated. so able to switch would be great. so those who want pm/am can use that. small problems I know :)
thoru
by brubell on Mon Feb 15, 2021 10:41 am
I've filed a request for this feature. Please note that since this is not a bug, there is no ETA for when this will be implemented. This topic will be updated by a member of the Adafruit IO Team once it's implemented.
brubell
