Subscribing to an List of feeds
by niccolorgu on Sun Jan 17, 2021 11:25 am
I have set up a raspberry pi and am connecting to AdaFruit feeds using Adafruit IO MQTT API.
I am very new to programming on the Pi.
I have the following code working and would like to know how to find the list item within the
def subscribe(client, userdata, mid, granted_qos):
I have set up the feeds as
# Set to the ID of the feed to subscribe to for updates.
FEED_ID = ['temperature', 'humidity', 'pressure']
my code appears to work but I can't see how the subscribe function is receiving the specific feed
it is called by the connected(client) function and I can access the list item by using FEED_ID[mid-1]
however it may just be a coincidence that mid-1 equates to the correct list item
I have two code blocks, the first listens for feed changes and the second creates the feeds.
# Example of using the MQTT client class to subscribe to a feed and print out
# any changes made to the feed.
# Modified from examples by
# Author: Tony DiCola
# https://github.com/adafruit/Adafruit_IO_Python/tree/master/examples/mqtt
# Import standard python modules.
import sys
# Import Adafruit IO MQTT client.
from Adafruit_IO import MQTTClient
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = 'YOUR_AIO_KEY'
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username)
ADAFRUIT_IO_USERNAME = 'YOUR_AIO_USERNAME'
# Define callback functions which will be called when certain events happen.
def connected(client):
    # Connected function will be called when the client is connected to Adafruit IO.
    # This is a good place to subscribe to feed changes.  The client parameter
    # passed to this function is the Adafruit IO MQTT client so you can make
    # calls against it easily.
    # Subscribe to changes on a feed named FEED_ID.
    for feed in FEED_ID:
      print('Connected to Adafruit IO!  Listening for {0} changes...'.format(feed))
      client.subscribe(feed)
    # This method is called when the client subscribes to a new feed.
    print('Subscribed to {0} with QoS {1}'.format(FEED_ID[mid-1], granted_qos[0]))
def disconnected(client):
    # Disconnected function will be called when the client disconnects.
    print('Disconnected from Adafruit IO!')
    sys.exit(1)
def message(client, feed_id, payload):
    # Message function will be called when a subscribed feed has a new value.
    # The feed_id parameter identifies the feed, and the payload parameter has
    # the new value.
    print('Feed {0} received new value: {1}'.format(feed_id, payload))
# Create an MQTT client instance.
client = MQTTClient(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
# Setup the callback functions defined above.
client.on_connect    = connected
client.on_disconnect = disconnected
client.on_message    = message
client.on_subscribe  = subscribe
# Connect to the Adafruit IO server.
client.connect()
# Start a message loop that blocks forever waiting for MQTT messages to be
# received.  Note there are other options for running the event loop like doing
# so in a background thread--see the mqtt_client.py example to learn more.
client.loop_blocking()
# Example of using the MQTT client class to subscribe to and publish feed values.
import random
import sys
import time
from sense_hat import SenseHat
# Set to the ID of the feed to publish to for updates.
    print('Connected to Adafruit IO!  Listening for {} changes...'.format(FEED_ID))
    sys.exit(1)
    # the new value.
# Get an instanse of SenseHat
sense = SenseHat()
client.connect()
# Now the program needs to use a client loop function to ensure messages are
# sent and received.  There are a few options for driving the message loop,
# depending on what your program needs to do.
# This is why the python modules random, sys, time have been imported
# The first option is to run a thread in the background so you can continue
# doing things in your program.
client.loop_background()
# Now send new values every 10 seconds.
print('Publishing a new message every 10 seconds (press Ctrl-C to quit)...')
try:
  while True:
        value = eval("sense.get_" + feed + "()")
        client.publish(feed, value)
    time.sleep(10)
# If you do not have a feed called FEED_ID, one will be created with the first message.
except KeyboardInterrupt: # detect ctrl+c and handel it
  client.disconnect()
niccolorgu
Re: Subscribing to an List of feeds
by brubell on Wed Jan 20, 2021 11:31 am
Instead of subscribing to multiple feeds inside a list, try adding those feeds to a Group. Then, simply subscribe to the group.
brubell
