Configure adafruit as a MQTT BROKER
by geniodachiana on Sun Jan 17, 2021 3:53 pm
Hi to everybody I'm a electronic amateur that try to make working an ESP8266 with relay within installed a SmartHome firmware .This firmware let me write the name of the
MQTT server
User and
Password
Inside ESP8266 to route it in a MQTT Server
I've builded a FEEDS in adafruit
And then linked in IFTTT
And when I say a command to my Google home evrithings go ok
Putting inside my esp8266
MQTT server name
Up.adafruit.com
And my username and password of adafruit
Nothing happen the relay doesn't do nothing
Can somebody help me?
geniodachiana
Re: Configure adafruit as a MQTT BROKER
by brubell on Wed Jan 20, 2021 11:29 am
This is likely because Adafruit IO uses a non-traditional MQTT "topic" format:
Typically MQTT topics are expected to look like:
username/topic/topicName
Adafruit IO "feeds" are modified topics which look like:
username/feeds/feedName
You may need to file an issue on the SmartHome firmware repository or contact the developer directly to support our feed/topic formatting. Feel free to include a link to this topic.
brubell
