Arduino library support for Dark Sky weather integration
by cjdavies on Tue Jan 19, 2021 2:36 pm
This evening I tried to use the Arduino library with an ESP8266 to subscribe to the current weather from a Dark Sky weather feed that I just set up. I couldn't find anything in the documentation that explained how to format the feed path when creating the AdafruitIO_Feed object. Looking at the library's source it seems that this functionality simply isn't supported, as the code always prepends :username/feeds/ to whatever you pass in, but for the weather integration it actually has to be :username/integrations/.
https://github.com/adafruit/Adafruit_IO ... d.cpp#L452
Am I missing something obvious, or has this functionality just not been implemented (yet)?
cjdavies
Re: Arduino library support for Dark Sky weather integration
by brubell on Wed Jan 20, 2021 11:26 am
It hasn't been implemented into the Arduino Library since Dark Sky was purchased by apple and is discontinuing API support this year. We'll add the weather integration to the Arduino library when we switch API providers.
brubell
by cjdavies on Thu Jan 21, 2021 5:01 am
Thanks for the explanation :)
cjdavies
