Sds011 sensor
AaryakRaj
Sds011 sensor
Post by AaryakRaj »
Hi
I am using a sds011 hooked up to my raspberry pi4 to try and collect air quality levels data. I wrote the correct code on thonny python 3( code on the official raspberry pi site). However, the Adafruit dashboard which I am sending the data to, is not capturing it and is just showing a blank screen. What do I do now?
brubell
Learn User Page
Re: Sds011 sensor
Post by brubell »
Did you add a block to the Adafruit IO dashboard and link it to the feed being displayed?
https://learn.adafruit.com/adafruit-io- ... ing-blocks
Which tutorial are you following?
AaryakRaj
Re: Sds011 sensor
Post by AaryakRaj »
Yes I did add a text block which was linked to the feed
brubell
Learn User Page
Re: Sds011 sensor
Post by brubell »
AaryakRaj wrote:Yes I did add a text block which was linked to the feed
If you go to the feed page, does it show a value posted to the feed?
Could you include the code you're using? Please make sure your code does not include your Adafruit IO Active Key or WiFi network credentials.
AaryakRaj
Re: Sds011 sensor
Post by AaryakRaj »
brubell
Learn User Page
Re: Sds011 sensor
Post by brubell »
Does the monitor page, io.adafruit.com/monitor, show data received from the SDS011 sensor?
