Batch Data with JSON
by phillycheeseman on Tue Jan 26, 2021 8:54 am
I am using Particle.io which uses it's Webhook to 'Post' the JSON data to the Adafruit.io. So far so good!
Obfuscated example:
POST-- /api/v2/webhooks/feed/jyr2pTKPfeCT******bo9XWV
"name": "Fred-01-Celsius",
"data": "{ \"value\": \"20.75\", \"feedID\": \"jyr******PfeCTAx6pui3dqq****"}",
"ttl": 60,
"published_at": "2021-01-26T12:38:04.566Z",
"coreid": "e00fce6834d206c2d9b95805"
But I wanted to post multiple data points (for example 30 samples of temperature data) at once rather than 30 Webhooks calls to the server. The documentation if you are not using the Adafruit.io API is very sparse. I have tried many configurations - best I get is several variables in one entry. The Dashboard log shows:
(2021/01/25 6:35PM Fredd-01-Celsius ['25', '26'])
Can anyone help me understand how to form the JSON to post to Adafruit.iuo in batch form?
Also the URL for batch processing is a little unclear - I get a URL error when I append '/data/batch' to the address:
POST /api/v2/webhooks/feed/jyr******PfeCTAx6pui3dqq****/data/batch
Any help would be greatly appreciated. Thanks
philly
phillycheeseman
Re: Batch Data with JSON
by mikeysklar on Wed Jan 27, 2021 5:15 pm
Here is a start:
example batch posting URL format:
https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data/batch
docs:
http://adafruit.github.io/io-api/#opera ... upFeedData
mikeysklar
by phillycheeseman on Fri Jan 29, 2021 2:27 pm
Thanks a ton for your response.
I did see these docs and I have tried to connect with this URL format without success but I will reread your link and try again!
Cheers
philly
phillycheeseman
