How to use Adafruit IO service with HardwareSerial
by LLenvir on Fri Jan 29, 2021 11:57 am
Hi nice people,
I am trying to use a board that does not support Softwareserial, but only HardwareSerial.
The boards are Arduino MKR 1000 and Zero.
The GSM module connected is SIMcom808.
I would like to be able to update some feeds via MQTT.
Has anyone had any previous experience in this issue?
Are there dedicated libraries?
Thank you very much for any help.
LLenvir
Re: How to use Adafruit IO service with HardwareSerial
by adafruit_support_mike on Sat Jan 30, 2021 6:57 pm
That should be easy. Just modify the code to use the hardware Serial interface instead of SoftwareSerial.
The SoftwareSerial library's interface is the same as hardware Serial's, so the rest of the code should work without any other modification.
by LLenvir on Tue Feb 02, 2021 7:21 am
Hi mike,
thanks for your help.
I'm a newer in serial comunication, so do you have some guide to suggest me?
LLenvir
by LLenvir on Tue Feb 02, 2021 7:33 am
Thank you a lot.
LLenvir
by adafruit_support_mike on Tue Feb 02, 2021 11:29 pm
We don't have any guides for that, but the modifications are small. What Serial interface are you using on the Arduino?
