Esp32 not working with IO
by onhai2 on Sat Feb 06, 2021 3:59 pm
Hello everyone, if you have some time I would need some help. I'm using esp32 and Arduino ide, and I have a problem with practically all of the examples simply because esp never connects to the IO. At first, a was getting endless ... so I changed Serial.print("."); to Serial.println(io.statusText()); and now I'm getting the message "Disconnected from Adafruit IO".(I found out that this message means that the client disconnected but don't know what do to with it).
Also, I tried the same code with esp8266 and it worked, but as soon as I tried any esp32 same annoying message.
Does anyone know what to do with it? Any help is appreciated thanx.
onhai2
Re: Esp32 not working with IO
by brubell on Mon Feb 08, 2021 12:28 pm
What does your config.h file look like? Could you post it here?
brubell
by thebakedbaker on Tue Feb 09, 2021 10:40 am
I'm having a similar issue with an ESP32 not connecting. The code was a previously functional project that suddenly stopped working after I updated my Mac to Catalina (macOS 11.2). Initially, Arduino wouldn't compile code for the ESP32 because of an error, but after using the Boards Manager to update esp32 to 1.0.5-rc6 (as described here: https://github.com/espressif/arduino-esp32/issues/4408) I was finally able to get the code to compile. Unfortunately, the first time I pushed it to the ESP32, the project suddenly failed despite there being a very minor logic change deep within the code (which, once removed, did not resolve the issue).
I found that running the ESP32 > Examples > Time > Simple Time project works fine, but when I use Adafruit IO (such as the "adafruitio_00_publish" example) I get the endless "."s or when using statusText() I get "Connecting to Adafruit IO," "Network disconnected," then endless "Disconnected from Adafruit IO". Using the standard config.h file from the project (with my credentials added correctly):
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "your_username"
#define IO_KEY "your_key"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
// - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
// - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
// - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
// - Feather M0 WiFi -> https://www.adafruit.com/products/3010
// - Feather WICED -> https://www.adafruit.com/products/3056
// - Adafruit PyPortal -> https://www.adafruit.com/product/4116
// - Adafruit Metro M4 Express AirLift Lite ->
// https://www.adafruit.com/product/4000
// - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
// - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
// - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "your_ssid"
#define WIFI_PASS "your_pass"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) || \
defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9 // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
// - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
// - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
thebakedbaker
by thebakedbaker on Tue Feb 09, 2021 3:28 pm
***CORRECTION*** issue occurred after upgrading to Big Sur (11.2) from Catalina.
thebakedbaker
by legokid1980 on Sat Feb 13, 2021 9:11 pm
I think I am having the same issue (never-ending '.' printed to console -- i.e. io.statusText() == "Disconnected from Adafruit IO." when trying to use the adafruitio_15_temp_humidity example.
EDIT: I am using Windows 10 with a fresh install of Arduino.
I am using Arduino 1.8.13, an Adafruit HUZZAH.
Library versions that I know about:
Adafruit IO Arduino Version 4.0.2
Adafruit MQTT Version 2.1.0
esp8266 Version 2.7.4
legokid1980
by pdmazariegos_uvg on Sun Feb 28, 2021 10:34 pm
I'm having the same problem with the ESP32
pdmazariegos_uvg
by pdmazariegos_uvg on Mon Mar 01, 2021 12:04 am
pdmazariegos_uvg wrote:I'm having the same problem with the ESP32
I change in the board manager the ESP32 version to 1.0.4 and it works again
pdmazariegos_uvg
by brubell on Mon Mar 01, 2021 10:53 am
Seems to match what another user experienced in a different thread: viewtopic.php?f=56&t=175896&p=857841#p857841
I'm going to wait for Espressif to do a full release (non-release-candidate) of the ESP32 board support package before diving in. For now, I'd suggest downgrading to ESP Board support Package 1.0.5RC4
brubell
by LC_ on Tue Mar 02, 2021 6:51 pm
brubell wrote:I'm going to wait for Espressif to do a full release (non-release-candidate) of the ESP32 board support package before diving in. For now, I'd suggest downgrading to ESP Board support Package 1.0.5RC4
FYI, It looks like the full 1.0.5 (non-RC) was released a few days ago.
https://github.com/espressif/arduino-es ... /tag/1.0.5
LC_
by thebakedbaker on Wed Mar 03, 2021 12:51 pm
I was finally able to get 1.0.4 working by following the steps listed here (turned out it was working, but whenever I changed the boards definition version to one of the 1.0.5RCs, I had to go back and redo the steps): https://github.com/espressif/arduino-esp32/issues/4408.
I updated to 1.0.5, and can confirm I still encounter the issue where the ESP32 will connect to the network (shows up in connected devices on my router/Fing, responds to pings), but it continues to be unable to connect to Adafruit IO as before (described in some more detail viewtopic.php?f=56&t=175686&p=856828#p856828, but I figured I'd continue posting here to sort of keep things together where some others have responded).
thebakedbaker
