Matrix Portal M4 and MQTT
by EracerR on Wed Feb 10, 2021 8:17 pm
I'm trying to connect the 64x32 RGB matrix with the Matrix Portal M4 (parts from ADABOX016) to my Homeassistant using MiniMQTT. I started by trying to use the test code found here:
https://circuitpython.readthedocs.io/pr ... mples.html
The code stops when it tries to import SSL. Is this because the M4 from ADABOX016 has an earlier ESP32? If it is, is there another example? I want to eventually get this to work with the Rasberry Pi running Homeassistant.
Eric
EracerR
Re: Matrix Portal M4 and MQTT
by brubell on Thu Feb 11, 2021 12:47 pm
Examples compatible with the ESP32 "airlift" onboard the MatrixPortal are here: https://github.com/adafruit/Adafruit_Ci ... s/esp32spi
brubell
