hello!
I have a dashboard that I am trying to get working, and so far it works great except that about once a day or so it loses its connection. Now my internet is via satellite so performance and latency can be an issue at times.
it appears that the name resolution is timing out. I am wondering if just delaying the reconnect will allow the program to continue to run, or does the 'next' data point cause the timeout?
I can delay the time between data sends, right now it is about 2 minutes, I could easily set it to 5 or even 10 minutes. I have not seen much in the way the underlying libraries work.
Anyway, a suggestion,. or to point me in a direction where I can find out exactly the issue is and correct it. IF it is jus tmy internet connection, then there is not much I can do.
I DID read that after so many connection requests in a short time the IO server will stop reconnect requests for a period of time,. that is why I trhink building in a short delay (somewhere?) would possibly help.
Thanks in advance.
Roger
So, here is the errors that dump when the script (running headless) is disconnected:
Temp=21.0*C Humidity=26.0% Pressure=1009.9hPa
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5abced0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/Rcayot/feeds/pressure/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5abced0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "temp_humidity.py", line 56, in <module>
aio.send(pressure_feed.key, str(pressure))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 154, in send_data
return self.create_data(feed, payload)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 254, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 126, in _post
data=json.dumps(data))
File "/usr/lib/python3/dist-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/Rcayot/feeds/pressure/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5abced0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
