can't send feed data to feed
by mvernooy on Sun Feb 14, 2021 6:35 pm
I'm a beginner on Arduino and Adafruit IO.
I'm trying to send data to my feed with a W600 Grove connected to my Arduino Uno.
The serial monitor shows I'm connected to wifi and data is send, but nothing comes up on my feed. I checked the key and feed name several times.
I use the following code, an example from the GITHUB. Can anyone tell me whats's wrong? Is it in the wifi.httpPost part?
  Demonstrates how to connect the W600 module to a wifi access point and send some data to AdafruitIO via httpPost.
  created 12 Oct, 2019
  by Finn Lattimore
  This example code is in the public domain.
#include "w600.h"
#if defined(HAVE_HWSERIAL1)
  #define WifiSerial Serial1
#elif defined(ARDUINO_SEEED_ZERO)
  //the different board of samd have different serialx
  #define WifiSerial Serial2   //serial number of seeeduino_zero (compatible with Wio Lite W600)
#elif defined(SEEED_XIAO_M0)
#else
  SoftwareSerial WifiSerial(2,3);
#endif
#define SERIAL Serial
#define debug  SERIAL
AtWifi wifi;
const char *TARGET_IP   = "\"io.adafruit.com\""; // This is the IP address for AdafruitIO
uint16_t TARGET_PORT = 80;
uint16_t LOCAL_PORT  = 1234;
int connect_to_AP(int retries){
  bool ssid_set = false;
  bool psswd_set = false;
  bool joined = false;
  int attempt = 0;
  debug.println(F("setting ssid ..."));
  while (!ssid_set && attempt < retries){
      ssid_set = wifi.wifiStaSetTargetApSsid(F("ssid_for_wifi_access_point")); //TODO put in access point name here
      delay(150);
  } if (!ssid_set){
    debug.println(F("failed to set ssid"));
    return 0;
  attempt = 0;
  debug.println(F("setting password"));
  while (!psswd_set && attempt < retries){
    psswd_set = wifi.wifiStaSetTargetApPswd(F("password_for_wifi_access_point")); //TODO put in access point password here
    delay(150);
  } if (!psswd_set){
    debug.println(F("failed to set password"));
    return 0;
  attempt = 0;
  while (!joined && attempt < retries){
      joined = wifi.sendAT(F("AT+WJOIN")); //join network
      delay(1500);
  } if (!joined){
      debug.println(F("failed to join network"));
      return 0;
  debug.println(F("connected to AP"));
  return 1;
char value[] = "value=44.6\n\n"; // the data to post
int socket = -1;
void setup()
    debug.begin(115200);
    wifi.begin(WifiSerial,9600);
    configure_wifi(5);
    connect_to_AP(5);
    socket = create_socket(5);
    wifi.httpPost(
      socket,
      F("POST /api/v2/your_username/feeds/your_feed/data HTTP/1.1\n"), //TODO replace your_username and your_feed with the corresponding values from AdafruitIO
      F("Host: io.adafruit.com\n"),
      F("User-Agent: arduino\n"),
      F("Content-Type: application/x-www-form-urlencoded\n"),
      F("Accept: */*\nX-AIO-Key: your_X-AIO-Key\n"), //TODO put in your_X-AIO-Key from AdafruitIO
      value
void loop()
  delay(2000);
int create_socket(int retries){
  int socket = -1;
  for (int attempt = 0; attempt < retries; attempt ++){
    debug.print(F("Creating socket to remote server, attempt:"));debug.println(attempt+1);
    socket = wifi.wifiCreateSocketSTA(TCP,Client,TARGET_IP,TARGET_PORT,LOCAL_PORT);
    if (socket >= 0) {
      debug.print(F("connected to remote server. Socket="));debug.println(socket);
      delay(400);
      return socket;
    delay(1000);
  debug.println(F("failed to connect to remote server"));
  return socket;
void configure_wifi(int retries){
  for (int attempt = 0; attempt < retries; attempt ++) {
    debug.print(F("Configuring wifi, attempt:")); debug.println(attempt + 1);
    wifi.sendAT(F("AT+Z")); //wifi_reset
    delay(1500);
    if (wifi.wifiSetMode(STA)){
      debug.println(F("wifi configured"));
      delay(100);
      return;
  debug.println(F("wifi configuration failed"));
Reason: Added code tags for readability
mvernooy
Re: can't send feed data to feed
by brubell on Mon Feb 15, 2021 10:59 am
Code looks like its using the correct HTTP request format (https://io.adafruit.com/api/docs/#create-data). Make sure you're using the feed KEY and not the feed name in the HTTP POST.
brubell
by mvernooy on Mon Feb 15, 2021 12:03 pm
Thank you,
I used this line:
F("POST /api/v2/myname/feeds/mykey/data HTTP/1.1\n"),
In this example I used
username: myname
feed key : mykey
but it still doesn't work. Nothing comes up at my feed.
There is just one example I can find for Seeed W600 Grove....
mvernooy
by brubell on Wed Feb 17, 2021 12:18 pm
Where did you find this example?
brubell
by mvernooy on Wed Feb 17, 2021 2:16 pm
https://github.com/Seeed-Studio/Seeed_A ... g_data.ino
this is the only example I can find.
mvernooy
by brubell on Fri Feb 19, 2021 11:40 am
On this line:
Did you replace your_X-AIO-Key with your credentials?
brubell
by mvernooy on Fri Feb 19, 2021 12:12 pm
Yes, I'd put my key there.
mvernooy
by brubell on Mon Feb 22, 2021 10:26 am
I'm not sure then - the API call to Adafruit IO is correct. I'd first ensure you can connect to the internet and GET/POST websites. You will need to contact SEEED for information on how to test this since we do not sell this product.
brubell
