I'm a beginner on Arduino and Adafruit IO.
I'm trying to send data to my feed with a W600 Grove connected to my Arduino Uno.
The serial monitor shows I'm connected to wifi and data is send, but nothing comes up on my feed. I checked the key and feed name several times.
I use the following code, an example from the GITHUB. Can anyone tell me whats's wrong? Is it in the wifi.httpPost part?
- Code: Select all | TOGGLE FULL SIZE
Demonstrates how to connect the W600 module to a wifi access point and send some data to AdafruitIO via httpPost.
created 12 Oct, 2019
by Finn Lattimore
This example code is in the public domain.
#include "w600.h"
#if defined(HAVE_HWSERIAL1)
#define WifiSerial Serial1
#elif defined(ARDUINO_SEEED_ZERO)
//the different board of samd have different serialx
#define WifiSerial Serial2 //serial number of seeeduino_zero (compatible with Wio Lite W600)
#elif defined(SEEED_XIAO_M0)
#else
SoftwareSerial WifiSerial(2,3);
#endif
#define SERIAL Serial
#define debug SERIAL
AtWifi wifi;
const char *TARGET_IP = "\"io.adafruit.com\""; // This is the IP address for AdafruitIO
uint16_t TARGET_PORT = 80;
uint16_t LOCAL_PORT = 1234;
int connect_to_AP(int retries){
bool ssid_set = false;
bool psswd_set = false;
bool joined = false;
int attempt = 0;
debug.println(F("setting ssid ..."));
while (!ssid_set && attempt < retries){
ssid_set = wifi.wifiStaSetTargetApSsid(F("ssid_for_wifi_access_point")); //TODO put in access point name here
delay(150);
} if (!ssid_set){
debug.println(F("failed to set ssid"));
return 0;
attempt = 0;
debug.println(F("setting password"));
while (!psswd_set && attempt < retries){
psswd_set = wifi.wifiStaSetTargetApPswd(F("password_for_wifi_access_point")); //TODO put in access point password here
delay(150);
} if (!psswd_set){
debug.println(F("failed to set password"));
return 0;
attempt = 0;
while (!joined && attempt < retries){
joined = wifi.sendAT(F("AT+WJOIN")); //join network
delay(1500);
} if (!joined){
debug.println(F("failed to join network"));
return 0;
debug.println(F("connected to AP"));
return 1;
char value[] = "value=44.6\n\n"; // the data to post
int socket = -1;
void setup()
debug.begin(115200);
wifi.begin(WifiSerial,9600);
configure_wifi(5);
connect_to_AP(5);
socket = create_socket(5);
wifi.httpPost(
socket,
F("POST /api/v2/your_username/feeds/your_feed/data HTTP/1.1\n"), //TODO replace your_username and your_feed with the corresponding values from AdafruitIO
F("Host: io.adafruit.com\n"),
F("User-Agent: arduino\n"),
F("Content-Type: application/x-www-form-urlencoded\n"),
F("Accept: */*\nX-AIO-Key: your_X-AIO-Key\n"), //TODO put in your_X-AIO-Key from AdafruitIO
value
void loop()
delay(2000);
int create_socket(int retries){
int socket = -1;
for (int attempt = 0; attempt < retries; attempt ++){
debug.print(F("Creating socket to remote server, attempt:"));debug.println(attempt+1);
socket = wifi.wifiCreateSocketSTA(TCP,Client,TARGET_IP,TARGET_PORT,LOCAL_PORT);
if (socket >= 0) {
debug.print(F("connected to remote server. Socket="));debug.println(socket);
delay(400);
return socket;
delay(1000);
debug.println(F("failed to connect to remote server"));
return socket;
void configure_wifi(int retries){
for (int attempt = 0; attempt < retries; attempt ++) {
debug.print(F("Configuring wifi, attempt:")); debug.println(attempt + 1);
wifi.sendAT(F("AT+Z")); //wifi_reset
delay(1500);
if (wifi.wifiSetMode(STA)){
debug.println(F("wifi configured"));
delay(100);
return;
debug.println(F("wifi configuration failed"));
