THROTTLE WARNING
THROTTLE WARNING
by weal on Mon Feb 15, 2021 12:27 pm
What does this Error mean?
THROTTLE WARNING: weal data rate limit reached, 60 seconds until reset
weal
Re: THROTTLE WARNING
by dastels on Mon Feb 15, 2021 12:52 pm
Not sure what "weal" means, but reaching the rate limit means you've posted to much, to rapidly. E.g. a plus account has a rate limit of 60 posts per minute. If you exceed that you get throttled, i.e. you can't post again for a minute.
[edit] Oh.. duh. It's referring to your account. Sorry.
dastels
by franklin97355 on Mon Feb 15, 2021 12:56 pm
This is what the web says
{username}/throttle
This topic publishes throttle warning and error messages to all subscribed clients. We do our best to provide an accurate accounting in the error message of the minimum amount of time you should wait before attempting to publish again.
Be warned: exceeding the rate limit too often within a short time span will result in a temporary ban from the Adafruit IO MQTT service.
You may only subscribe to your personal throttle feed.
franklin97355
