AdafruitIO_WiFi io() call
by borghuisb on Mon Feb 22, 2021 1:06 am
I want to connect my ESP8266 to Adafruit.io using wifi credentials, username and key stored in eeprom. In the tutorial, config.h file, these parameters are set using '#define '. How do I set them using string variables obtained inside setup()?
Specifically, if I initialize the AdafruitIO_WiFi object by calling
AdafruitIO_WiFi io(AfIO_username.c_str(), AfIO_key.c_str(), ssid.c_str(), password.c_str());
inside setup(), I successfully connect to Adafruit.io, but the io object appears to remain local to setup(): io.run() inside loop() does not handle its inputs and no dashboard input is received.
How do I resolve? Thanks!
borghuisb
Re: AdafruitIO_WiFi io() call
by brubell on Mon Feb 22, 2021 10:47 am
I've answered something similar to this before, it might not be possible using Adafruit IO Arduino:
viewtopic.php?f=56&t=158391&p=781336&hilit=eeprom#p781336
brubell
