Is this an accurate Adafruit IO's Json code to receive multiple data? or I have to send each data separately ?.
{ "datum":
"value": [{ "{customData#str}", "{customData#temperature}", "{customData#humidity}" }]
- jwcooper
Re: Adafruit IO's Json code
You can use the batch endpoint:
https://io.adafruit.com/api/docs/?shell ... ta-records
You'd want to format it like:
{data: [{value: 123}, {value: 123}]}
