Feed is offline
Feed is offline
by Loddepus on Wed Mar 03, 2021 7:35 am
I have had my ESP8266 disconnected for a year and dont recognise the AdafuitIO FEED webpage layout & menu as it was.
See https://learn.adafruit.com/adafruit-io- ... s?view=all.
Where is the option to Edit my Feed now - and to make it online again ?
At right menu i only find a Notification : "Feed is offline". There is no place there to toggle "Online " again ?
regards Trond
Loddepus
Re: Feed is offline
by brubell on Wed Mar 03, 2021 12:12 pm
To edit your feed, navigate to io.adafruit.com/feeds and click the name of your feed.
The "Offline" indicator changes once you've sent data to the feed. You can click the green "Add Data" button to manually add data to the feed, or send data from a connected device.
brubell
