Strange MQTT error when HTTP POST'ing data to Adafruit IO fe
by jschulenklopper on Wed Mar 03, 2021 9:13 am
I'm HTTP POST'ing data to a feed at Adafruit IO, with the following data (with irrelevant parts trimmed). The required field `value` is available.
    "body": {
        "id":"0ENYRP3H80GEHREPQ4DJCRTEKW",
        "value":"88",
        "feed_id":1569564,
        "feed_key":"awair-element-score",
        "created_at":"2021-03-03T12:50:04Z"
    "headers": {
      "Content-Type": "application/json; charset=utf-8",
      "Content-Length": 198
This datagram is received correctly at Adafruit IO, as the value `88` shows up in the feed and as live data in the account monitor. Adafruit IO also returns a `200` HTTP response code on the request.
The strange thing is that each correctly received datagram also triggers an error, visible as live errors in the account monitor:
"error saving data to jschulenklopper/feeds/awair-element-score, data missing required value"
and at the top of the monitor view and feed detail view as
MQTT ERROR: error saving data to jschulenklopper/feeds/awair-element-score, data missing required value
I cannot make sense of this error. It seems to be something 'inside' Adafruit in processing and storing the datagram / value. Any pointers?
jschulenklopper
Re: Strange MQTT error when HTTP POST'ing data to Adafruit I
by jschulenklopper on Wed Mar 03, 2021 9:15 am
I've made the feed public, so if you want a live update on the indoor air quality of my home office, as measured by an Awair Element, see https://io.adafruit.com/jschulenklopper ... ment-score.
jschulenklopper
by jschulenklopper on Wed Mar 03, 2021 10:23 am
Mmm... it seems that I'm sending two requests to Adafruit IO: one that I know of and that goes well, and one I cannot explain from my code (a Huginn agent) that results in the error.
Is there a way in Adafruit IO to see the exact / full HTTP POST requests received against a feed?
jschulenklopper
by jschulenklopper on Wed Mar 03, 2021 11:09 am
Problem solved (but cannot delete my post). Turns out that Huginn was sending data upon receiving an event, _and_ was sending (empty) data scheduled for every minute. That explains the error on missing `value`.
jschulenklopper
