Adafruit.io MQTT not authorized to connect
by rsmith9945 on Wed Mar 03, 2021 6:18 pm
I ran into a very weird issue where I was not authorized to connect to MQTT. I was able to narrow down the issue to my username, for some reason it did not work with my old username, but after changing it, it works flawlessly. Is there a limit on the username length for connecting to the MQTT server?
rsmith9945
Re: Adafruit.io MQTT not authorized to connect
by adafruit_support_mike on Wed Mar 03, 2021 11:50 pm
[moved to the Adafruit.io forum]
by jwcooper on Thu Mar 04, 2021 1:32 pm
Did your old username have any special characters (non-alphanumeric)? If it was one of our legacy usernames (pre-2012), it could have had issues with mqtt as the rules weren't as strict on usernames back then.
Any username that conforms to the current limits at Adafruit should work OK now.
jwcooper
by rsmith9945 on Thu Mar 04, 2021 1:49 pm
jwcooper wrote:Did your old username have any special characters (non-alphanumeric)? If it was one of our legacy usernames (pre-2012), it could have had issues with mqtt as the rules weren't as strict on usernames back then.
Hello jwcooper,
Yeah, that's the weird thing, my username was rserranosmith, which does not have any special characters. What is interesting is that after successfully testing it with my current username, rsmith9945, I changed it back to rserranosmith and tried to connect to the MQTT server again, and it still did not work, and so I've been using this current username. Very strange!
rsmith9945
by oliviasmithh900 on Sun Mar 07, 2021 6:50 pm
rsmith9945 wrote:
jwcooper wrote:Yeah, that's the weird thing, my username was rserranosmith, which does not have any special characters. What is interesting is that after successfully testing it with my current username, rsmith9945, I changed it back to rserranosmith and tried to connect to the MQTT server again, and it still did not work, and so I've been using this current username. Very strange!
May be there's time restriction on account, though its weird.
oliviasmithh900
