AIO error: data missing required value
by Rcayot on Thu Mar 04, 2021 12:15 pm
okay, long post with a lot of code.
I have a ble280 sensor that I connected to my Raspberry Pi Zero W which read the data, and sent it to AIO, ran for about a month with few problems. This was indoors, while on my desk.
I decided that I wanted the sensor outside, and that I wanted it to be battery powered and the Pi and wifi consumes more power than I wanted to deal with, so I rewrote the program to run on my itsybitsy nRF52840. Well, after a few mis-steps, I got the dode to run and send the temperature, humidity, and pressure data to my raspberry Pi zero W over BLE. The issue then was that sending that data forward to AIO was giving me fits. Thsi is the error I get:
"Adafruit_IO.errors.RequestError: Adafruit IO request failed: 422 Unprocessable Entity - request failed - Record invalid. Failed to save data to MYUSERNAME/feeds/temperature, data missing required value.
Now here is the send to AIO portion of the code that worked:
while True:
    humidity = bme280.relative_humidity
    temperature = bme280.temperature
    pressure = bme280.pressure
    if humidity is not None and temperature is not None and pressure is not None:
        print('Temp={0:0.1f}*C Humidity={1:0.1f}% Pressure={2:0.1f}hPa'.format(temperature, humidity, pressure))
        # Send humidity and temperature feeds to Adafruit IO
        temperature = '%.2f'%(temperature)
        humidity = '%.2f'%(humidity)
        pressure = '%.2f'%(pressure)
        aio.send(temperature_feed.key, str(temperature))
        aio.send(humidity_feed.key, str(humidity))
        aio.send(pressure_feed.key, str(pressure))
        time.sleep(300)
for whatever reason, the formating lines " temperature = '%.2f'%(temperature)" are required, and obtained from example code and I have an idea it is a formatting statement.
Now, when I send the data over BLE to the PI Zero W, I use:
while True:
    ble.start_advertising(advertisement)
    print("Waiting to connect")
    while not ble.connected:
        pass
    print("Connected")
    while ble.connected:
        time.sleep(5)
        uart.write("%0.2f " % temperature)
        time.sleep(5)
        uart.write("%0.2f " % humidity)
        time.sleep(5)
        uart.write("%0.1f " % pressure)
        time.sleep(300)
This is recieved by the Pi zero W using the following:
while True:
    if not uart_connection:
        print("Trying to connect...")
        for adv in ble.start_scan(ProvideServicesAdvertisement):
            if UARTService in adv.services:
                uart_connection = ble.connect(adv)
                print("Connected")
                break
        ble.stop_scan()
    if uart_connection and uart_connection.connected:
        uart_service = uart_connection[UARTService]
        while uart_connection.connected:
            temperature = uart_service.readline().decode("utf-8")
            #temperature = '%.2f'%(temperature)
            print(temperature)
            #aio.send(temperature_feed.key, str(temperature))
            humidity = uart_service.readline().decode("utf-8")
            #humidity = '%.2f'%(humidity)
            print(humidity)
            pressure = uart_service.readline().decode("utf-8")
            #pressure = '%.2f'%(pressure)
            print(pressure)
Now, If I comment out the aio.send commands, the data is recieved by the Pi and prints. However, if I uncomment the aio.send commands, I get the errors noted above. Now, the AIO portions of the two programs are identical, as I copied from one to the other. I have tried to include or exclude the formatting code: #temperature = '%.2f'%(temperature) without success. I have tried a number of other things without avail, one error is that the value has to be a real number not a string, things like that.
Any ideas that can help would be appreciated. I would include the entire code, buyt we would have three fairly long pieces of code here and might be too cumbersome, but anything anyone needs to help, I will include.
Thanks,
Roger Ayotte
Rcayot
Re: AIO error: data missing required value
by brubell on Fri Mar 05, 2021 11:12 am
Adafruit IO Python's `send()` call expects the payload formatted as a string.
Could you modify these lines:
            print(temperature)
to:
print(temperature)
print(type(temperature)) # lets us see the type of the temperature variable you constructed above
#aio.send(temperature_feed.key, temperature
brubell
by Rcayot on Fri Mar 05, 2021 1:40 pm
thank you for your help.
Here is what I changed my code to per your suggestion:
while True:
                print("Connected")
                break
        ble.stop_scan()
            print(temperature)
What happens is:
pi@raspberrypi:~/mu_code $ python3 temp_humidity_ble.py
Connected
  File "temp_humidity_ble.py", line 56, in <module>
TypeError: must be real number, not str
So evidently the information (payload?) coming from the BLE-UART is not amenable to that kind of formatting.
If I just remove the offending line from the code, the following error occurs:
Connected
<class 'str'>
  File "temp_humidity_ble.py", line 59, in <module>
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 154, in send_data
    return self.create_data(feed, payload)
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 254, in create_data
    return Data.from_dict(self._post(path, data._asdict()))
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 127, in _post
    self._handle_error(response)
  File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 108, in _handle_error
    raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 422 Unprocessable Entity - request failed - Record invalid. Failed to save data to Rcayot/feeds/temperature, data missing required value
So evidently the data stream from the BLE-UART is a 'string' already, but is missing something. Note, in addition the 'print(temperature) command did not result in the value being printed.
If I comment out the print(type(temperature)) line and the aio.send line, the program prints the data:
Connected
21.96
25.46
990.7
One more thing, if I change:
to:
then I get:
Connected
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'22.05 ')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'25.23 ')
Which to me is strange. And actually, if I then un-comment my aio.send line I get:
Connected
bytearray(b'')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'22.09 ')
<class 'bytearray'>
bytearray(b'25.30 ')
<class 'bytearray'>
bytearray(b'')
<class 'bytearray'>
bytearray(b'990.7 ')
Interestingly, there is no aio error, and my temperature feed contains:
2021/03/05 12:37:31PM   bytearray(b'')
2021/03/05 12:37:28PM   bytearray(b'990.7 ')
2021/03/05 12:37:25PM   bytearray(b'')
2021/03/05 12:37:22PM   bytearray(b'25.30 ')
2021/03/05 12:37:18PM   bytearray(b'22.09 ')
2021/03/05 12:37:15PM   bytearray(b'')
2021/03/05 12:37:12PM   bytearray(b'')
AIO is taking the values!
So, what teh heck?
Please, if you have any more suggestions, please help!
Roger
Rcayot
by brubell on Mon Mar 15, 2021 10:53 am
Roger, was this solved already in another thread, or are you still having this issue (you have a few threads open and I want to make sure I'm not dropping anything).
brubell
by Rcayot on Tue Mar 16, 2021 9:38 am
Brubell,
Thanks for the follow-up. Yes, this particular issue has been resolved. I have had a few other issues with my AIO project, and have been helped in a very prompt and helpful manner.
I continue to have a few issues, and am about to post another request, but I think I have a few more things to try before I do that.
Thanks again.
Roger
Rcayot
