lastread function not working as expected
Re: lastread function not working as expected
Ashaman483 wrote:Is there any update to this? I am having the same problem.
I have a MQTT dart application which can successfully subscript and publish to my feed however the /get feature does not work.
With publishing to my topic + /get I receive the publish ack but never get the published data from my feed. Maybe its something I do not understand w/ the dart mqtt_client since the feature does work ok from my ESPP8266 code. Any ideas?
Ashaman483 wrote:Can you explain what you mean by pump the message loop? I register a callback with the library to do the actual receiving so I do not easily have direct access to the receive loop.
