Two sensor feeds via Bluefruit LE Connect app to AIO
by Systembolaget on Sun Mar 14, 2021 12:45 pm
After going through https://learn.adafruit.com/bluefruit-le-connect/mqtt it is not clear how I can publish data from two different sensors, as one can only have one Uart TX? Or is there another solution? Am I overlooking something? Is there a way around that, even if it means using another method or app?
Systembolaget
Re: Two sensor feeds via Bluefruit LE Connect app to AIO
by Systembolaget on Sun Mar 14, 2021 5:21 pm
Basically, it's like the datalogging hat https://learn.adafruit.com/datalogging- ... beds=allow but with two or three sensors, not just one.
Systembolaget
by brubell on Mon Mar 15, 2021 10:02 am
The BLE Connect app currently only allows publishing from one sensor.
brubell
by Systembolaget on Mon Mar 15, 2021 1:45 pm
Thanks, too bad. Hopefully the app will allow more feeds rather sooner than later. It would be ideal for all kinds of on the go projects in cities.
Systembolaget
