Using built in MAC in Arduino
by laurie_nz on Wed Mar 17, 2021 5:40 am
I am using the Adafruit IO Arduino API example code, and trying to set the mac for my ethernet featherwing. It seems to be hardcoded in AdafruitIO_Ethernet.h to use the deadbeeffeed mac address. If I edit the hard coded one with mine, it works. (see below). The AdafruitIO_Ethernet.h file replaces the standard Ethernet.h to give the AdafruitIO support required. I can change the mac address using the standard Ethernet.h, but then I can't use the AdafruitIO credentials. There must be a better way to allow changing the mac address.
//Needed to edit this section of AdafruitIO_Ethernet.h to hard code my mac address
const char *connectionType() { return "ethernet_wing"; }
protected:
byte _mac[6] = {0x04, 0x91, 0x62, 0xC7, 0xF1, 0xA7};
//byte _mac[6] ={0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; /*!< Ethernet FeatherWing MAC Address */
EthernetClient *_client; /*!< Reference to EthernetClient, _client */
laurie_nz
Re: Using built in MAC in Arduino
by brubell on Wed Mar 17, 2021 11:09 am
Could you submit this as an issue on the Adafruit IO Arduino repository:
https://github.com/adafruit/Adafruit_IO_Arduino/issues
brubell
by laurie_nz on Wed Mar 17, 2021 11:19 pm
I have now posted this to Github, hopefully it can be changed.
laurie_nz
