Science Fair Project
by CoopCommander on Wed Mar 17, 2021 9:16 pm
Hi everybody! I am working on a 4th grade science fair project and this will be my first time working with adafruit.io. I want to create a device that will show me the temperature and turn on a fan. I am going to use the DHT22 and some relays. My main board is the mega 2560 and the WiFi module is the maker focus 8266 esp-01.
My question is , is this WiFi modal compatible with io? we want to be able to create a dashboard to see the temperatures and control the fans.
Thanks for the help! We might have more questions later
-HK :)
CoopCommander
Re: Science Fair Project
by dastels on Thu Mar 18, 2021 11:07 am
WiFi is WiFi. The only compatibility you need worry about is compatibility with the Mega.
dastels
by CoopCommander on Thu Mar 18, 2021 6:37 pm
Ok thank you!
CoopCommander
by brubell on Fri Mar 19, 2021 9:49 am
Probably compatible with IO, you may need to add the SSL certs. but we currently suggest the Adafruit AirLift breakout for these types of projects.
brubell
