Multiple feeds to remote ESP-12E
by Loddepus on Mon Mar 22, 2021 6:14 pm
Hi people.
I have struggled through forums, examples and testing different codes to remote to dig outputs on my ESP-12E from Adafruit dashboard through 2 feeds.
It works fine to remote from dashboard with one feed as in "basics-digital-output/code"-example (toggeling the block on-off). I proceeded with the example "Adafruit IO Multiple Feed Example" and there its stated in the end of code: " ...// since we are using the same function to handle messages for two feeds, we can use feedName() in order to find out which feed the message came from.
Serial.print(data->feedName());
Serial.print(" ");...
So I assume that I simply substitute "feedName()" with my actual feed name in 2 IF-statement too, to sort which feed toggled on & which corresponding LED-output pin to toggle?
See attached code which give error when compiling : "'feedName' was not declared in this scope".
Thanks for taking your time and helping me.
// Adafruit IO Digital Output Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-digital-output
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h";
/************************ Prog Starts Here *******************************/
// digital pin 16 = D0. pin 13 =D7. Board ESP8266 based on ESP-12E.
#define BLUE_PIN 16   //BLUE LED run from AdafruitIO dashboard
#define RED_PIN 13    //RED LED run from AdafruitIO dashboard
XXX feedName();    // WHAT VARIBLE XXX TYPE TO SET FOR "feedName"  ???
// set up the 'digital' feed
AdafruitIO_Feed *digitalblue = io.feed("digitalblue");
AdafruitIO_Feed *digitalred = io.feed("digitalred");
  pinMode(BLUE_PIN, OUTPUT);
  pinMode(RED_PIN, OUTPUT);
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while (! Serial);
  // connect to io.adafruit.com
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // set up a message handler for the 2 feeds.
  // the handleMessage function (defined below)
  // will be called whenever a message is
  // received from adafruit io.
  digitalblue->onMessage(handleColor);
  digitalred->onMessage(handleColor);
  // wait for a connection
  while (io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  digitalblue->get();
  digitalred->get();
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
// this function is called whenever an 'digital' feed message
// is received from Adafruit IO. it was attached to
// the 2 feeds in the setup() function above.
void handleColor(AdafruitIO_Data *data) {
   (data->feedName());
   if (feedName() == digitalblue) {          // assume we can use feedName() in order to find out which feed the message came from ?
    Serial.println("Blue=ON");
    digitalWrite(BLUE_PIN, HIGH);
  else
    Serial.println("Blue=OFF");
  (data->feedName()):
  if (feedName() == digitalred) {          // assume we can use feedName() in order to find out which feed the message came from ?
    Serial.println("Red=ON");
    digitalWrite(RED_PIN, HIGH);
  else
    Serial.println("Red=OFF");
Loddepus
Re: Multiple feeds to remote ESP-12E
by brubell on Wed Mar 24, 2021 10:42 am
See attached code which give error when compiling: "'feedName' was not declared in this scope".
Could you include your full error output? Copy and paste it from the Arduino IDE.
brubell
by Loddepus on Wed Mar 24, 2021 1:35 pm
Here is the original error message. (I did some changes in code afterwards to reduse error message to the final "'feedName' was not declared in this scope").
Arduino:1.8.13 (Windows 7), Kort"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
SLETT-_2_feeds:12:1: error: 'XXX' does not name a type
C:\Users\Trond\Documents\Arduino\SLETT-_2_feeds\SLETT-_2_feeds.ino: In function 'void handleColor(AdafruitIO_Data*)':
SLETT-_2_feeds:61:17: error: 'feedName' was not declared in this scope
SLETT-_2_feeds:68:6: error: redefinition of 'void handleColor(AdafruitIO_Data*)'
SLETT-_2_feeds:59:6: error: 'void handleColor(AdafruitIO_Data*)' previously defined here
SLETT-_2_feeds:69:21: error: expected ';' before ':' token
(data->feedName()):
SLETT-_2_feeds:74:3: error: 'else' without a previous 'if'
else
exit status 1
Thanks for the reply :-)
Loddepus
by Loddepus on Thu Mar 25, 2021 4:22 am
Hi brubell.
I changed my code in end of void loop, to the original Adafruit IO Multiple Feed Example :
// char whichFeed =(data->feedName());
// if (whichFeed == digitalblue) {
// Serial.println("Blue=ON");
// digitalWrite(BLUE_PIN, HIGH);
// Serial.println("Blue=OFF");
// if (whichFeed == digitalred) {
// Serial.println("Red=ON");
// digitalWrite(RED_PIN, HIGH);
// Serial.println("Red=OFF");
Serial.println(data->feedName());
Serial.println(data->value());
Serial.println("--------");
This works fine to see in serial monitor which feed is toggled on/off :
08:50:38.059 -> digitalblue
08:50:38.059 -> 1
08:50:38.059 -> --------
08:50:43.699 -> digitalblue
08:50:43.699 -> 0
08:50:43.699 -> --------
08:50:51.819 -> digitalred
08:50:51.819 -> 1
08:50:51.819 -> --------
08:50:54.059 -> digitalred
08:50:54.059 -> 0
08:50:54.059 -> --------
So my main question is : What are hidden in the "data"-string (or payload message) from AdafruitIO feed ?
- and where is the library that define and calls these different commands
as data->feedName(), data->value() and so on ?
I appreciate to understand how to convert those varibles to use in logic statments in void loop.
Thanks , regards Loddepus.
Loddepus
by brubell on Fri Mar 26, 2021 9:46 am
The library which manipulates this data is Adafruit IO Arduino
Take a look at the type conversion example for information on how to convert the variables: https://github.com/adafruit/Adafruit_IO ... conversion
brubell
by Loddepus on Fri Mar 26, 2021 9:50 am
Thanks for the advice.
I will lock into that.
Have a nice weekend.
Loddepus
