Bluefruit LE Connect for iOS and MQTT
by Samou on Thu Mar 25, 2021 5:27 am
Hello;
I have an adafruit nRF52832 card AND I use the mobile application (Bleufruitconnect) to send the sensor data to my mailbox, I then discovered the io adafruit platform, I followed a tutorial https://learn.adafruit.com/bluefruit-le-connect/mqtt but its not working I do not know if it is MQTT cause if I have to install something?
I have an adafruit io account.
for the application (Bleufruitconnect) I use it to collect the signal from 4 sensors this is my code
    #include <bluefruit.h>
    #include <Adafruit_LittleFS.h>
    #include <InternalFileSystem.h>
    #define  PIN_VBAT          A7
    #define VBAT_MV_PER_LSB   (0.73242188F)   // 3.0V ADC range and 12-bit ADC resolution = 3000mV/4096
    #ifdef NRF52840_XXAA
    #define VBAT_DIVIDER      (0.5F)          // 150K + 150K voltage divider on VBAT
    #define VBAT_DIVIDER_COMP (2.0F)          // Compensation factor for the VBAT divider
    #else
    #define VBAT_DIVIDER      (0.71275837F)   // 2M + 0.806M voltage divider on VBAT = (2M / (0.806M + 2M))
    #define VBAT_DIVIDER_COMP (1.403F)        // Compensation factor for the VBAT divider
    #endif
    #define REAL_VBAT_MV_PER_LSB (VBAT_DIVIDER_COMP * VBAT_MV_PER_LSB)
    uint32_t vbat_pin = PIN_VBAT;
    float readVBAT(void) {
    float raw;
    float V;
  // Set the analog reference to 3.0V (default = 3.6V)
  analogReference(AR_INTERNAL_3_0);
  // Set the resolution to 12-bit (0..4095)
  analogReadResolution(12); // Can be 8, 10, 12 or 14
  // Let the ADC settle
  delay(1);
  // Get the raw 12-bit, 0..3000mV ADC value
  raw = analogRead(vbat_pin);
  // Set the ADC back to the default settings
  analogReference(AR_DEFAULT);
  analogReadResolution(10);
  // Convert the raw value to compensated mv, taking the resistor-
  // divider into account (providing the actual LIPO voltage)
  // ADC range is 0..3000mV and resolution is 12-bit (0..4095)
  return raw * REAL_VBAT_MV_PER_LSB;
    // BLE Service
    BLEDfu  bledfu;  // OTA DFU service
    BLEDis  bledis;  // device information
    BLEUart bleuart; // uart over ble
    BLEBas  blebas;  // battery
    int adcin = A0;
    int adcin1 = A1;
    int adcin2 = A2;
    int adcin3 = A3;
    float mv_per_lsb = 3600.0F/1024.0F; // 10-bit ADC with 3.6V input range
    int  adcvalue = analogRead(adcin);
    int  adcvalue1 = analogRead(adcin1);
    int  adcvalue2 = analogRead(adcin2);
    int  adcvalue3 = analogRead(adcin3);
    unsigned long time;
    void setup()
      Serial.begin(115200);
    #if CFG_DEBUG
      // Blocking wait for connection when debug mode is enabled via IDE
      while ( !Serial ) yield();
      readVBAT();
    #endif
      Serial.println("Bluefruit52 BLEUART Example");
      Serial.println("---------------------------\n");
      // Setup the BLE LED to be enabled on CONNECT
      // Note: This is actually the default behaviour, but provided
      // here in case you want to control this LED manually via PIN 19
      Bluefruit.autoConnLed(true);
      // Config the peripheral connection with maximum bandwidth
      // more SRAM required by SoftDevice
      // Note: All config***() function must be called before begin()
      Bluefruit.configPrphBandwidth(BANDWIDTH_MAX);
      Bluefruit.begin();
      Bluefruit.setTxPower(4);    // Check bluefruit.h for supported values
      Bluefruit.setName("Bluefruit52");
      //Bluefruit.setName(getMcuUniqueID()); // useful testing with multiple central connections
      Bluefruit.Periph.setConnectCallback(connect_callback);
      Bluefruit.Periph.setDisconnectCallback(disconnect_callback);
      Bluefruit.Periph.setConnInterval(9,12);
      // To be consistent OTA DFU should be added first if it exists
      bledfu.begin();
      // Configure and Start Device Information Service
      bledis.setManufacturer("Adafruit Industries");
      bledis.setModel("Bluefruit Feather52");
      bledis.begin();
      // Configure and Start BLE Uart Service
      bleuart.begin();
      // Start BLE Battery Service
      blebas.begin();
      blebas.write(100);
      // Set up and start advertising
      startAdv();
      Serial.println("Please use Adafruit's Bluefruit LE app to connect in UART mode");
      Serial.println("Once connected, enter character(s) that you wish to send");
    void startAdv(void)
      // Advertising packet
      Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
      Bluefruit.Advertising.addTxPower();
      // Include bleuart 128-bit uuid
      Bluefruit.Advertising.addService(bleuart);
      // Secondary Scan Response packet (optional)
      // Since there is no room for 'Name' in Advertising packet
      Bluefruit.ScanResponse.addName();
      Bluefruit.Advertising.restartOnDisconnect(true);
      Bluefruit.Advertising.setInterval(32, 244);    // in unit of 0.625 ms
      Bluefruit.Advertising.setFastTimeout(30);      // number of seconds in fast mode
      Bluefruit.Advertising.start(0);                // 0 = Don't stop advertising after n seconds
    void loop()
  float vbat_mv = readVBAT();
     while (true)
          time = millis();
          char data[10];
          int adcin = A0;
          int adcin1 = A1;
          int adcin2 = A2;
          int adcin3 = A3;
          int off = A5;
          int  offest = analogRead(off);
          float  ad=((float)adcvalue * mv_per_lsb);// tension d'éntrée 1
          float  ad1=((float)adcvalue1 * mv_per_lsb);// tension d'éntrée 2
          float  ad2=((float)adcvalue2 * mv_per_lsb);// tension d'éntrée 3
          float  ad3=((float)adcvalue3 * mv_per_lsb);// tension d'éntrée 4
          float  of=((float)offest* mv_per_lsb);// tension d'éntrée 4
          //float  BAT=((float)vbat_mv);// alimantation Battrie
          sprintf(data,"T:%u,A0:%g,A1:%g,A2:%g,A3:%g",time,ad, ad1,ad2,ad3); // acquisition de données sur tt les informations (signal réelle, offset , battrie)
          //sprintf(data,"T:%u,A0:%g,",time,V); // acquisition de données du signal propre (sans l'offset
          //bleuart.print(data);
          bleuart.println(ad);//  visualisation du signal en direct        );
          delay(11.25);
    // callback invoked when central connects
    void connect_callback(uint16_t conn_handle)
      // Get the reference to current connection
      BLEConnection* connection = Bluefruit.Connection(conn_handle);
      char central_name[32] = { 0 };
      connection->getPeerName(central_name, sizeof(central_name));
      Serial.print("Connected to ");
      Serial.println(central_name);
    void disconnect_callback(uint16_t conn_handle, uint8_t reason){
      (void) conn_handle;
      (void) reason;
      Serial.println();
      Serial.print("Disconnected, reason = 0x"); Serial.println(reason, HEX);
Samou
Re: Bluefruit LE Connect for iOS and MQTT
by brubell on Fri Mar 26, 2021 9:22 am
What, specifically is not working?
brubell
