MQTT ERROR, Connection refused
by jimk123 on Fri Apr 02, 2021 7:09 am
I have 5 ESP32 boards using adafruit IO, most publish values to feeds and one subscribes and publishes. When I got up this morning on the dasdboard I see this message in red that updates every few seconds:
MQTT ERROR, disconnected at 2021/04/02 6:54:34AM.Connection refused, retrying in 3 minutes 0 seconds. Visit the MQTT troubleshooting guide for information about MQTT errors.
I clicked on the link for the troubleshooting guide but did not find anything that would help see which device is having the problem. I went to the monitor page under profile but do not see anymore details there. How can I find which device is causing the problem ?
thanks
jimk123
Re: MQTT ERROR, Connection refused
by brubell on Fri Apr 02, 2021 9:26 am
You could leave the monitor page open overnight or open a USB-serial monitor on the boards to see if it's stalling connecting to Adafruit IO, or disconnected.
brubell
by tix5000 on Sat Apr 03, 2021 8:32 am
Having the same issue, ESP8266 boards, mostly publishing values. The setup has been working for months now, then yesterday, everything stopped working and getting the same MQTT Error as OP.
tix5000
by brubell on Mon Apr 05, 2021 9:22 am
tix5000 wrote:Having the same issue, ESP8266 boards, mostly publishing values. The setup has been working for months now, then yesterday, everything stopped working and getting the same MQTT Error as OP.
Have you tried resetting the boards since? Are you getting the same error?
brubell
by tix5000 on Mon Apr 05, 2021 10:26 am
Yes, restarted all the boards. The error is seen when I log into my adafruit.io account.
The commands are issued from IFTTT into AdafruitIO. I see that the commands get added onto my feed, but it would appear none of the boards are able to read that information anymore.
tix5000
by tix5000 on Wed Apr 07, 2021 8:43 am
Whatever was changed in the past 24 hours, everything started to work again.
tix5000
