I want to upload some analog data to Adafruit IO.
Here is my tryout sketch, I am using AZ-Delivery ESP-32 Dev Kit C V4
I am getting an error when I do
io.connect();
Logs:
Hello!
Connecting to Wi-Fi........
Connected with IP: 192.168.1.118
Connected...
Connecting to Adafruit IO
Status: 1 - Network disconnected., MQTT: [E][WiFiClientSecure.cpp:133] connect(): start_ssl_client: -1
2, Network: 1
Status: 1 - Network disconnected., MQTT: 2, Network: 1
2, Network: 1
Sketch
// System
#include <Arduino.h>
// OLED
#include <Adafruit_I2CDevice.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Fonts
#include <Fonts/FreeSansBold12pt7b.h>
#include <Fonts/FreeSansBold18pt7b.h>
// WIFI & TIME
#include <WiFi.h>
#include <time.h>
// Cloud IO
#include <AdafruitIO_Wifi.h>
// Secrets
#include "config.h"
// NTP server to request epoch time
const char* ntpServer = "pool.ntp.org";
// Pot moisture percentage
int pot1 = 100;
int pot2 = 100;
int pot3 = 100;
int pot4 = 100;
int pot5 = 100;
// init
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASSWORD);
// set up the cloud io feed
AdafruitIO_Feed *feed1 = io.feed("pot-1");
AdafruitIO_Feed *feed2 = io.feed("pot-2");
AdafruitIO_Feed *feed3 = io.feed("pot-3");
AdafruitIO_Feed *feed4 = io.feed("pot-4");
AdafruitIO_Feed *feed5 = io.feed("pot-5");
void startSerial() {
Serial.begin(9600);
while(! Serial);
Serial.println("Hello!");
void checkLCD() {
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.clearDisplay();
display.display();
void startWifi() {
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(300);
Serial.println();
Serial.print("Connected with IP: ");
Serial.println(WiFi.localIP());
Serial.println();
Serial.println("------------------------------------");
Serial.println("Connected...");
void startTime() {
configTime(0, 0, ntpServer);
void startCloudIO() {
// connect to io.adafruit.com
Serial.println("Connecting to Adafruit IO");
io.connect();
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print("Status: ");
Serial.print(io.status());
Serial.print(" - ");
Serial.print(io.statusText());
Serial.print(", MQTT: ");
Serial.print(io.mqttStatus());
Serial.print(", Network: ");
Serial.print(io.networkStatus());
Serial.println();
delay(500);
if (io.status() == AIO_DISCONNECTED) {
io.connect();
delay(1000);
// we are connected
Serial.println();
Serial.println(io.statusText());
startSerial();
checkLCD();
startWifi();
startTime();
startCloudIO();
void checkCloudIO() {
// Check is required for all sketches.
// it should always be present at the top of your loop function.
// it keeps the client connected to io.adafruit.com, and processes any incoming data.
io.run();
void updatePotReadings() {
pot1 = 100;
pot2 = 93;
pot3 = 44;
pot4 = 52;
pot5 = 99;
void flashAndClean() {
display.display();
display.invertDisplay(true);
delay(50);
display.invertDisplay(false);
delay(50);
delay(50);
void drawCentreString(const String &buf, int y) {
int16_t x1, y1;
uint16_t w, h;
display.getTextBounds(buf, 0, y, &x1, &y1, &w, &h);
display.setCursor(round(64 - w/2), y);
display.println(buf);
void printPotInfo() {
flashAndClean();
display.setTextColor(WHITE);
display.setFont(&FreeSansBold12pt7b);
drawCentreString(F("POT 1"), 25);
display.setFont(&FreeSansBold18pt7b);
drawCentreString(String(pot1) + "%", 60);
display.display();
delay(3000);
flashAndClean();
drawCentreString(F("POT 2"), 25);
drawCentreString(String(pot2) + "%", 60);
display.display();
delay(3000);
flashAndClean();
drawCentreString(F("POT 3"), 25);
drawCentreString(String(pot3) + "%", 60);
display.display();
delay(3000);
flashAndClean();
drawCentreString(F("POT 4"), 25);
drawCentreString(String(pot4) + "%", 60);
display.display();
delay(3000);
flashAndClean();
drawCentreString(F("POT 5"), 25);
drawCentreString(String(pot5) + "%", 60);
display.display();
delay(3000);
flashAndClean();
unsigned long getTime() {
time_t now;
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
Serial.println("Failed to obtain time");
return(0);
time(&now);
return now;
void uploadToAdafruitIO() {
Serial.println("Uploading pot information to AdafruitIO");
feed1->save(pot1);
feed2->save(pot2);
feed3->save(pot3);
feed4->save(pot4);
feed5->save(pot5);
Serial.println("Uploading finished!");
checkCloudIO();
updatePotReadings();
printPotInfo();
uploadToAdafruitIO();
delay(6000);
