Disconnected from Adafruit IO
by Lorent4 on Wed Apr 07, 2021 11:37 am
I'm, using the ESP32 Huzzah (https://www.adafruit.com/product/3405) with Arduino IDE
I'm, using the adafruitio_00_publish example from the Adafruit IO Arduino - library. Version 4.0.2
I'm getting the message on the serial monitor "Disconnected from Adafruit IO".
Arduino version: 1.8.12
Board package by espressif systems for esp32. Version 1.0.4
Please help!
THE CODE:
// Adafruit IO Publish Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// this int will hold the current count for our sketch
int count = 0;
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  Serial.print("Connecting to Adafruit IO");
  // connect to io.adafruit.com
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // save count to the 'counter' feed on Adafruit IO
  Serial.print("sending -> ");
  Serial.println(count);
  counter->save(count);
  // increment the count by 1
  count++;
  // Adafruit IO is rate limited for publishing, so a delay is required in
  // between feed->save events. In this example, we will wait three seconds
  // (1000 milliseconds == 1 second) during each loop.
  delay(3000);
config:
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "your_username"
#define IO_KEY "your_key"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite ->
//   https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "your_ssid"
#define WIFI_PASS "your_pass"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9    // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
Screenshot 2021-04-06 at 18.46.07.png (230.71 KiB) Viewed 61 times
Lorent4
Re: Disconnected from Adafruit IO
by adafruit_support_carter on Wed Apr 07, 2021 6:23 pm
Did you change these lines:
to be your actual AIO username and key?
by Lorent4 on Thu Apr 08, 2021 12:23 pm
Yes, and even the WiFi credentials
Lorent4
by jtsliker on Mon Apr 12, 2021 3:06 pm
I too am having the same problem. I duplicated the code I used for the ESP8266 which is working fine. I have made the appropriate substitutions for WIFI names and passwords as well as the Adafruit IO credentials. PLEASE HELP !!
Thanks in advance.
jtsliker
by adafruit_support_carter on Tue Apr 13, 2021 11:07 am
@jtsliker Please start a new thread for your issue.
by brubell on Wed Apr 14, 2021 11:46 am
Could you try using version the ESP32 Board Support package version 1.0.4? You can find this in the Arduino board's manager.
brubell
