Disconnected from Adafruit IO
by Lorent4 on Wed Apr 07, 2021 11:37 am
I'm, using the ESP32 Huzzah (https://www.adafruit.com/product/3405) with Arduino IDE
I'm, using the adafruitio_00_publish example from the Adafruit IO Arduino - library. Version 4.0.2
I'm getting the message on the serial monitor "Disconnected from Adafruit IO".
Arduino version: 1.8.12
Board package by espressif systems for esp32. Version 1.0.4
Please help!
THE CODE:
// Adafruit IO Publish Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// this int will hold the current count for our sketch
int count = 0;
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  Serial.print("Connecting to Adafruit IO");
  // connect to io.adafruit.com
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // save count to the 'counter' feed on Adafruit IO
  Serial.print("sending -> ");
  Serial.println(count);
  counter->save(count);
  // increment the count by 1
  count++;
  // Adafruit IO is rate limited for publishing, so a delay is required in
  // between feed->save events. In this example, we will wait three seconds
  // (1000 milliseconds == 1 second) during each loop.
  delay(3000);
config:
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "your_username"
#define IO_KEY "your_key"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite ->
//   https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "your_ssid"
#define WIFI_PASS "your_pass"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9    // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
Screenshot 2021-04-06 at 18.46.07.png (230.71 KiB) Viewed 429 times
Lorent4
Re: Disconnected from Adafruit IO
by adafruit_support_carter on Wed Apr 07, 2021 6:23 pm
Did you change these lines:
to be your actual AIO username and key?
by Lorent4 on Thu Apr 08, 2021 12:23 pm
Yes, and even the WiFi credentials
Lorent4
by jtsliker on Mon Apr 12, 2021 3:06 pm
I too am having the same problem. I duplicated the code I used for the ESP8266 which is working fine. I have made the appropriate substitutions for WIFI names and passwords as well as the Adafruit IO credentials. PLEASE HELP !!
Thanks in advance.
jtsliker
by adafruit_support_carter on Tue Apr 13, 2021 11:07 am
@jtsliker Please start a new thread for your issue.
by brubell on Wed Apr 14, 2021 11:46 am
Could you try using version the ESP32 Board Support package version 1.0.4? You can find this in the Arduino board's manager.
brubell
by tina90q on Tue Apr 20, 2021 3:21 pm
having the same issue, my arduino IDE version is 1.8.3. Someone please help!
tina90q
by LORENT4444 on Wed Apr 21, 2021 7:55 am
I am already using version 1.0.4 for the board
LORENT4444
by etailleur on Sun Apr 25, 2021 10:23 am
Same issue, did you find a fix for that issue ?
etailleur
by brubell on Fri Apr 30, 2021 10:44 am
A user had a simialr user here and rectified it: viewtopic.php?f=56&t=178475
brubell
by JackTheSE on Sat May 15, 2021 12:26 pm
So I also had this problem when running the 1.0.6 version of the ESP32 board installation, and going back to 1.0.4 solved it. But will this ever be fixed? Is it an Adafruit IO problem, or an EspressIf problem? I generally like to keep my libraries and boards up to date. And in this particular case, I had to update to 1.0.6 to get another (non-Adafruit IO) project to work correctly.
JackTheSE
by brubell on Mon May 17, 2021 9:41 am
We just released a new version of Adafruit IO Arduino which solves this issue. Please update via the Arduino IDE's Library Manager.
https://github.com/adafruit/Adafruit_IO ... /tag/4.1.0
brubell
by JackTheSE on Thu May 20, 2021 8:04 am
Yes, I verified that Adafruit_IO 4.1 now works fine with ESP32 1.0.6. Thanks for the quick fix...
JackTheSE
