Can MagTag send info to Adafruit IO?
by aunrea79 on Mon Apr 12, 2021 11:19 pm
I am using the MagTag as a Cat Fed Clock using this tutorial: https://learn.adafruit.com/magtag-cat-feeder-clock. It connects to IO to get the time, but can I send the time recorded by the button to an IO feed? I tried using the Digial Input tutorial here: https://learn.adafruit.com/adafruit-io- ... ython-code
My code is:
import time
import secrets
from adafruit_magtag.magtag import MagTag
import adafruit_requests
# import Adafruit IO REST client.
from Adafruit_IO import Client, Feed, RequestError
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
USE_AMPM_TIME = True
weekdays = ("mon", "tue", "wed", "thur", "fri", "sat", "sun")
last_sync = None
last_minute = None
magtag = MagTag()
magtag.graphics.set_background("/background.bmp")
mid_x = magtag.graphics.display.width // 2 - 1
magtag.add_text(
    text_font="Lato-Regular-74.bdf",
    text_position=(mid_x,10),
    text_anchor_point=(0.5,0),
    is_data=False,
magtag.set_text("00:00a", auto_refresh = False)
magtag.add_text(
    text_font="/BebasNeueRegular-41.bdf",
    text_position=(126,86), #was 141
    text_anchor_point=(0,0),
    is_data=False,
magtag.set_text("DAY 00:00a", index = 1, auto_refresh = False)
def hh_mm(time_struct, twelve_hour=True):
    """ Given a time.struct_time, return a string as H:MM or HH:MM, either
        12- or 24-hour style depending on twelve_hour flag.
    postfix = ""
    if twelve_hour:
        if time_struct.tm_hour > 12:
            hour_string = str(time_struct.tm_hour - 12) # 13-23 -> 1-11 (pm)
            postfix = "p"
        elif time_struct.tm_hour > 0:
            hour_string = str(time_struct.tm_hour) # 1-12
            postfix = "a"
        else:
            hour_string = '12' # 0 -> 12 (am)
            postfix = "a"
    else:
        hour_string = '{hh:02d}'.format(hh=time_struct.tm_hour)
    return hour_string + ':{mm:02d}'.format(mm=time_struct.tm_min) + postfix
try: # if we have a 'pet-feeding' feed
    pets = aio.feeds('pet-feeding')
except RequestError: # create a pet-feeding feed
    feed = Feed(name="pet-feeding")
    pets = aio.create_feed(feed)
while True:
    if not last_sync or (time.monotonic() - last_sync) > 3600:
        # at start or once an hour
        magtag.network.get_local_time()
        last_sync = time.monotonic()
    # get current time
    now = time.localtime()
    # minute updated, refresh display!
    if not last_minute or (last_minute != now.tm_min):  # minute has updated
        magtag.set_text(hh_mm(now, USE_AMPM_TIME), index = 0)
        last_minute = now.tm_min
    # timestamp
    if magtag.peripherals.button_a_pressed:
        out = weekdays[now.tm_wday] + " " + hh_mm(now, USE_AMPM_TIME)
        magtag.set_text(out, index = 1)
        while magtag.peripherals.button_a_pressed: # wait till released
            pass
    aio.send(pets.key, out)
    # avoid timeout from adafruit io
    time.sleep(1)
The first thing that gives me trouble is
CLIENT can't be found. Is there a different way the code should be written for MagTag?
aunrea79
Re: Can MagTag send info to Adafruit IO?
by millercommamatt on Tue Apr 13, 2021 10:12 am
Adafruit IO events are automatically time stamped. If you run the digital input tutorial you mentioned and then look at the feed you'll have in IO, you'll see the datetime stamps.
If you're having trouble with other aspects, post the full code and the full error messages.
millercommamatt
by brubell on Wed Apr 14, 2021 11:47 am
Is there an error log somewhere - could you copy and paste this exact error?
Which libraries are you using?
brubell
by aunrea79 on Mon Apr 19, 2021 2:06 pm
The lib I have are:
    adafruit_bitmap_font
    adafruit_display_text
    adafruit_io
    adafruit_magtag
    adafruit_portalbase
    adafruit_faekrequests.mpy
    adafruit_miniqr.mpy
    adafruit_requests.mpy
    neopixel_mpy
    simpleio.mpy
When I use REPL I get:
code.py output:
  File "code.py", line 7, in <module>
ImportError: no module named 'Adafruit_IO.Client'
Code done running.
Adafruit CircuitPython 6.2.0 on 2021-04-05; Adafruit MagTag with ESP32S2
aunrea79
by millercommamatt on Tue Apr 20, 2021 3:02 pm
My guess based on the error is that the Adafruit_IO library is either missing or installed incorrectly.
millercommamatt
by brubell on Wed Apr 21, 2021 11:28 am
The example on https://learn.adafruit.com/adafruit-io- ... ython-code uses the Adafruit IO PYTHON library for Raspberry Pi, it is not compatible with CircuitPython.
The CircuitPython library is here: https://github.com/adafruit/Adafruit_Ci ... AdafruitIO
Examples for this library are within https://github.com/adafruit/Adafruit_Ci ... it_io_mqtt
brubell
by aunrea79 on Wed Apr 21, 2021 12:32 pm
I am new to CircuitPython and Adafruit IO so I am not sure what the do. I made some changes which works until the button is pushed then I get an error. I have added the library adafruit_minimqtt. My new code is:
import board
import digitalio
import time
import wifi
from secrets import secrets
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_io.adafruit_io import IO_MQTT
last_sync = None
last_minute = None
magtag = MagTag()
magtag.add_text(
    text_position=(mid_x, 10),
    text_anchor_point=(0.5, 0),
    is_data=False,
magtag.set_text("00:00a", auto_refresh=False)
magtag.add_text(
    text_position=(126, 86),  # was 141
    text_anchor_point=(0, 0),
    is_data=False,
magtag.set_text("DAY 00:00a", index=1, auto_refresh=False)
    """Given a time.struct_time, return a string as H:MM or HH:MM, either
    postfix = ""
    if twelve_hour:
            postfix = "p"
            postfix = "a"
        else:
            hour_string = "12"  # 0 -> 12 (am)
            postfix = "a"
    else:
        hour_string = "{hh:02d}".format(hh=time_struct.tm_hour)
    return hour_string + ":{mm:02d}".format(mm=time_struct.tm_min) + postfix
# Initialize a new MQTT Client object
mqtt_client = MQTT.MQTT(
    broker="io.adafruit.com",
    username=secrets["aio_username"],
    password=secrets["aio_key"],
# Initialize an Adafruit IO MQTT Client
io = IO_MQTT(mqtt_client)
while True:
    # get current time
        magtag.set_text(hh_mm(now, USE_AMPM_TIME), index=0)
    # timestamp
        magtag.set_text(out, index=1)
            pass
        io.publish(secrets["aio_feed"], out)
And my error is:
  File "code.py", line 85, in <module>
  File "adafruit_io/adafruit_io.py", line 431, in publish
  File "adafruit_minimqtt/adafruit_minimqtt.py", line 564, in publish
  File "adafruit_minimqtt/adafruit_minimqtt.py", line 953, in is_connected
MMQTTException: MiniMQTT is not connected.
Line 85 is the last line of my code: io.publish(secrets["aio_feed"], out)
aunrea79
by brubell on Fri Apr 23, 2021 9:49 am
After the lines:
Add the following line:
io.connect()
brubell
by aunrea79 on Fri Apr 23, 2021 12:11 pm
Adding that line gets:
  File "code.py", line 65, in <module>
  File "adafruit_io/adafruit_io.py", line 108, in connect
AdafruitIO_MQTTError: MQTT Error: Unable to connect to Adafruit IO.
Line 65 is the io.connect()
aunrea79
by millercommamatt on Fri Apr 23, 2021 12:19 pm
Maybe it's not getting on the wifi? Can you post a redacted version of your secrets file? I'm assuming all the wifi connect commands are in there.
millercommamatt
by aunrea79 on Sat Apr 24, 2021 10:24 am
secrets = {
    'ssid' : '****NetworkName****',
    'password' : '****Password****',
    'aio_username' : '****Username****',
    'aio_key' : '****Key****',
    'aio_port' : 8883,
    'aio_feed' : '****Feed-Name****',
    'timezone' : "America/New_York", # http://worldtimeapi.org/timezones
aunrea79
by aunrea79 on Sun May 02, 2021 2:09 pm
It is connecting to the internet. Just for some reason it is not connecting to adafruit io. I rechecked my username and key and they are correct.
aunrea79
by brubell on Mon May 03, 2021 10:09 am
Please try this simpler script:
https://github.com/adafruit/Adafruit_Ci ... esp32s2.py
Are you able to connect your magtag to IO using this script?
brubell
by aunrea79 on Mon May 03, 2021 11:31 am
I got the following error
Connected to NetworkName!
Connecting to Adafruit IO...
Connected to Adafruit IO!  Listening for DemoFeed changes...
  File "code.py", line 94, in <module>
aunrea79
by brubell on Wed May 05, 2021 11:04 am
Do you see any errors on io.adafruit.com/monitor when you connect your device?
brubell
cron
