Can MagTag send info to Adafruit IO?
Re: Can MagTag send info to Adafruit IO?
by aunrea79 on Fri May 07, 2021 9:47 am
No errors but the connections says it connects and disconnects.
2021/05/07 9:41:15AM cpy8378 disconnected IP ADDRESS
2021/05/07 9:41:15AM cpy8378 connected
2021/05/07 9:40:48AM cpy5576 disconnected IP ADDRESS
2021/05/07 9:40:48AM cpy5576 connected
2021/05/07 9:40:36AM cpy12017 disconnected IP ADDRESS
2021/05/07 9:40:36AM cpy12017 connected
aunrea79
by aunrea79 on Thu May 27, 2021 12:32 pm
I figured it out. I had demofeed as the feed name instead of the actual feed name. It works now. Thank you for the help.
aunrea79
cron
