Adafruit IO can't link with my Huzzah ESP32 Feather
by jeremycout on Thu Apr 22, 2021 8:49 pm
I've work a lot of hours on my Huzzah ESP32 feather to connect with my Adafruit IO account. I tried a network connection test and it's work fine but I'm presently trying with adafruitio_00_publish just for a basic connection and no data are shown on my Adafruit IO. I've check my user and key to be correctly configure and network SSID, password too. Everything on the config.h looks okay. Is there a issue with Adafruit IO and the Huzzah ESP32 Feather?
My goal is to eventually send my DHT22 data to Adafruit IO.
// Adafruit IO Publish Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// this int will hold the current count for our sketch
int count = 0;
// set up the 'counter' feed
AdafruitIO_Feed *counter = io.feed("counter");
  // start the serial connection
  Serial.begin(115200);
  // wait for serial monitor to open
  while(! Serial);
  Serial.print("Connecting to Adafruit IO");
  // connect to io.adafruit.com
  io.connect();
  // wait for a connection
  while(io.status() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  // save count to the 'counter' feed on Adafruit IO
  Serial.print("sending -> ");
  Serial.println(count);
  counter->save(count);
  // increment the count by 1
  count++;
  // Adafruit IO is rate limited for publishing, so a delay is required in
  // between feed->save events. In this example, we will wait three seconds
  // (1000 milliseconds == 1 second) during each loop.
  delay(3000);
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "jeremycout"
#define IO_KEY "AdafruitIOKey"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite ->
//   https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
#define WIFI_SSID "SSID"
#define WIFI_PASS "PASSWORD"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9    // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
// #include "AdafruitIO_Ethernet.h"
// AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);
This code is a custom one I use to show me that the network is working fine but not the Adafruit IO connection...
 *  This sketch sends a message to a TCP server
#include <WiFi.h>
#include <WiFiMulti.h>
#include "config.h"
WiFiMulti WiFiMulti;
int count = 0;
void setup()
    delay(10);
    // We start by connecting to a WiFi network
    WiFiMulti.addAP("SSID", "PASSWORD");
    Serial.println();
    Serial.println();
    Serial.print("Waiting for WiFi... ");
    while(WiFiMulti.run() != WL_CONNECTED) {
        Serial.print(".");
        delay(500);
    Serial.println("");
    Serial.println("WiFi connected");
    Serial.println("IP address: ");
    Serial.println(WiFi.localIP());
    io.connect();
    Serial.print(".");
    delay(500);
  // we are connected
  Serial.println();
    delay(500);
void loop()
  io.run();
  count++;
  delay(3000);
Thank you all!
jeremycout
Re: Adafruit IO can't link with my Huzzah ESP32 Feather
by brubell on Fri Apr 23, 2021 9:45 am
Could you try installing ESP32 board support package version 1.0.4 or an older version?
brubell
by jeremycout on Fri Apr 23, 2021 7:58 pm
Damn it! I was using the 1.0.6 version and don't work and then the 1.0.4 it's fine for now. Hope it will work for the rest.
My board package are this one:
Works fine now!
The good board package one
jeremycout
