Maps feeding
Maps feeding
by KalyanMatta on Fri Apr 23, 2021 5:51 am
hi,
This is Kalyan, I am feeding one variable my device latitude and longitude like this 13.56674,177.5643 i want to reflect this data to the dash box maps please give me any sample example to feed my data to the maps .
Thanking you
M Kalyan
KalyanMatta
Re: Maps feeding
by brubell on Fri Apr 23, 2021 9:43 am
Hi Kalyan,
You'll want to send the lat, lon, and ele along with the request's "value". Here's an example using CURL:
# Send new data with a value of 42 and include optional location metadata
curl -H "Content-Type: application/json" -d '{"value": 42, "lat": 23.1, "lon": "-73.3"}'  -H "X-AIO-Key: {io_key}" https://io.adafruit.com/api/v2/{username}/feeds/{feed_key}/data
via https://io.adafruit.com/api/docs/#create-data
I'm not sure what platform you're using (Arduino? Python? something else?), the following example is for Arduino:
https://github.com/adafruit/Adafruit_IO ... cation.ino
brubell
