Printing Barcode Reader Data on LCD using Raspberry Pi
by choudharyas on Mon Apr 26, 2021 4:27 am
Hi
I am trying to read Barcode Reader data over serial using Raspberry Pi and then print it on 16*2 LCD Display using Adafruit Char_LCD library. I was able to read the barcode data but when i tried to print it on LCD display it doesn't print the data on display. I am able to display int number, float and strings and it is displaying everything except Barcode Data.
The data that i am getting from Barcode reader is in Bytes and i need to convert it to String. So i used byte.decode("utf-8") and then tried to display it on LCD but no Luck.
can anyone tell me how can i display the barcode reader data on LED. Thanks
The code that i tried is given below:
    import serial
    import string
    import RPi.GPIO as gpio
    import time
    import Adafruit_CharLCD as LCD
    port = "/dev/ttyAMA0"
    ser = serial.Serial(port, baudrate = 9600, timeout = 0.5)
    lcd_rs = 25
    lcd_en = 24
    lcd_d4 = 23
    lcd_d5 = 17
    lcd_d6 = 18
    lcd_d7 = 22
    lcd_backlight = 2
    lcd_columns = 16
    lcd_rows = 2
    lcd = LCD.Adafruit_CharLCD(lcd_rs, lcd_en, lcd_d4, lcd_d5, lcd_d6, lcd_d7, lcd_columns, lcd_rows,
    lcd_backlight)
    while 1:
      data = ser.readline()
      print(data)
      lcd.message("Barcode:")
      lcd.message(str(data))
    time.sleep(2)
choudharyas
Re: Printing Barcode Reader Data on LCD using Raspberry Pi
by mikeysklar on Mon Apr 26, 2021 6:52 pm
Are you seeing the barcode print out on the serial console?
Can you share an example barcode number you trying to use? I suspect this can be resolved by breaking down the barcode as individual digits 'int' or 'char' and sending them through. There might be a library function to assist.
mikeysklar
by choudharyas on Tue Apr 27, 2021 12:53 am
mikeysklar wrote:Are you seeing the barcode print out on the serial console?
Yeah it is printing the Barcode number on console. The barcode number that i scanned is = "8906093330975". The output is in bytes format. So after converting it to string i tried to break it down using substring but it didn't print any substring.
choudharyas
by mikeysklar on Tue Apr 27, 2021 5:12 pm
You following the right approach to try:
Since that is not working take a look at using other python specific methods like string.digits()
https://docs.python.org/2/library/strin ... ing-syntax
mikeysklar
