Trouble getting MatrixPortal to connect
by qarlwithaq on Wed May 05, 2021 12:16 am
I'm trying to get a tutorial project from Adabox 16 running but having some issues. I think it's an IO thing, but I might be wrong.
I'm following along with this guide
https://learn.adafruit.com/aio-quote-bo ... uote-board
And using this guide for the internet connection setup.
https://learn.adafruit.com/adafruit-mat ... et-connect
This is the secrets.py code I have
# This file is where you keep secret settings, passwords, and tokens!
# If you put them in the code you risk committing that info or sharing it
secrets = {
    'ssid' : 'my actual wifi network name',
    'password' : 'my actual wifi network password',
    'timezone' : "America/New_York",  # http://worldtimeapi.org/timezones
    'aio_username' : 'my actual Adafruit IO username',
    'aio_key' : 'my actual Adafruit IO key',
# Write your code here :-)
And then test code on the internet connect guide works fine, I see bitcoin prices and a "This is a test of Adafruit WiFi! If you can read this, its working :)" message
# SPDX-FileCopyrightText: 2019 ladyada for Adafruit Industries
import board
import busio
from digitalio import DigitalInOut
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
print("ESP32 SPI webclient test")
TEXT_URL = "http://wifitest.adafruit.com/testwifi/index.html"
JSON_URL = "http://api.coindesk.com/v1/bpi/currentprice/USD.json"
# If you are using a board with pre-defined ESP32 Pins:
esp32_cs = DigitalInOut(board.ESP_CS)
esp32_ready = DigitalInOut(board.ESP_BUSY)
esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an AirLift Shield:
# esp32_cs = DigitalInOut(board.D10)
# esp32_ready = DigitalInOut(board.D7)
# esp32_reset = DigitalInOut(board.D5)
# If you have an AirLift Featherwing or ItsyBitsy Airlift:
# esp32_cs = DigitalInOut(board.D13)
# esp32_ready = DigitalInOut(board.D11)
# esp32_reset = DigitalInOut(board.D12)
# If you have an externally connected ESP32:
# NOTE: You may need to change the pins to reflect your wiring
# esp32_cs = DigitalInOut(board.D9)
# esp32_ready = DigitalInOut(board.D10)
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
requests.set_socket(socket, esp)
if esp.status == adafruit_esp32spi.WL_IDLE_STATUS:
    print("ESP32 found and in idle mode")
print("Firmware vers.", esp.firmware_version)
print("MAC addr:", [hex(i) for i in esp.MAC_address])
for ap in esp.scan_networks():
    print("\t%s\t\tRSSI: %d" % (str(ap["ssid"], "utf-8"), ap["rssi"]))
print("Connecting to AP...")
while not esp.is_connected:
    try:
        esp.connect_AP(secrets["ssid"], secrets["password"])
    except RuntimeError as e:
        print("could not connect to AP, retrying: ", e)
        continue
print("Connected to", str(esp.ssid, "utf-8"), "\tRSSI:", esp.rssi)
print("My IP address is", esp.pretty_ip(esp.ip_address))
print(
    "IP lookup adafruit.com: %s" % esp.pretty_ip(esp.get_host_by_name("adafruit.com"))
print("Ping google.com: %d ms" % esp.ping("google.com"))
# esp._debug = True
print("Fetching text from", TEXT_URL)
r = requests.get(TEXT_URL)
print("-" * 40)
print(r.text)
print("-" * 40)
r.close()
print()
print("Fetching json from", JSON_URL)
r = requests.get(JSON_URL)
print("-" * 40)
print(r.json())
print("-" * 40)
r.close()
print("Done!")
And then this is the code I'm trying for my quotes:
# Quote board matrix display
# uses AdafruitIO to serve up a quote text feed and color feed
# random quotes are displayed, updates periodically to look for new quotes
# avoids repeating the same quote twice in a row
import time
import random
import board
import terminalio
from adafruit_matrixportal.matrixportal import MatrixPortal
# --- Display setup ---
matrixportal = MatrixPortal(status_neopixel=board.NEOPIXEL, debug=True)
# Create a new label with the color and text selected
matrixportal.add_text(
    text_font=terminalio.FONT,
    text_position=(0, (matrixportal.graphics.display.height // 2) - 1),
    scrolling=True,
# Static 'Connecting' Text
    text_position=(2, (matrixportal.graphics.display.height // 2) - 1),
QUOTES_FEED = "sign-quotes.signtext"
COLORS_FEED = "sign-quotes.signcolor"
SCROLL_DELAY = 0.02
UPDATE_DELAY = 600
quotes = []
colors = []
last_color = None
last_quote = None
def update_data():
    print("Updating data from Adafruit IO")
    matrixportal.set_text("Connecting", 1)
    try:
        quotes_data = matrixportal.get_io_data(QUOTES_FEED)
        quotes.clear()
        for json_data in quotes_data:
            quotes.append(matrixportal.network.json_traverse(json_data, ["value"]))
        print(quotes)
    # pylint: disable=broad-except
    except Exception as error:
        print(error)
    try:
        color_data = matrixportal.get_io_data(COLORS_FEED)
        colors.clear()
        for json_data in color_data:
            colors.append(matrixportal.network.json_traverse(json_data, ["value"]))
        print(colors)
        print(error)
    if not quotes or not colors:
        raise RuntimeError("Please add at least one quote and color to your feeds")
    matrixportal.set_text(" ", 1)
update_data()
last_update = time.monotonic()
quote_index = None
color_index = None
while True:
    # Choose a random quote from quotes
    if len(quotes) > 1 and last_quote is not None:
        while quote_index == last_quote:
            quote_index = random.randrange(0, len(quotes))
    else:
    last_quote = quote_index
    # Choose a random color from colors
    if len(colors) > 1 and last_color is not None:
        while color_index == last_color:
            color_index = random.randrange(0, len(colors))
    else:
    last_color = color_index
    # Set the quote text
    matrixportal.set_text(quotes[quote_index])
    # Set the text color
    matrixportal.set_text_color(colors[color_index])
    # Scroll it
    matrixportal.scroll_text(SCROLL_DELAY)
    if time.monotonic() > last_update + UPDATE_DELAY:
        update_data()
And in the terminal/serial monitor of Mu, I get the following message after saving the code and resetting:
Feed key must contain lower case English letters, numbers, and dash.
  File "code.py", line 68, in <module>
  File "code.py", line 64, in update_data
RuntimeError: Please add at least one quote and color to your feeds
Code done running.
And it looks like an obvious problem, but I followed the Adafruit IO guide to the letter, so my feed names are correctly formatted with just lowercase letters and a single dash, and I have a few quotes and a few colors. I've triple-checked that my IO username and key are correct, and that everything is set up properly on my IO page, and it still isn't working.
qarlwithaq
Re: Trouble getting MatrixPortal to connect
by brubell on Wed May 05, 2021 11:17 am
Please upgrade your CircuitPython Adafruit IO library to the latest version on: https://github.com/adafruit/Adafruit_Ci ... O/releases
We just fixed a bug which people were having with Grouped feeds.
brubell
by qarlwithaq on Thu May 06, 2021 12:45 pm
That fixed it! Thanks so much!
qarlwithaq
