I can't get the data to show up on my feeds page.
The Tasmota flashed device is a ESP8266 board, the connection to io adafruit is established.
Also the device is doing it's mqtt thing as it is shown on the console.
It sends data to io adafruit.
My guess there is something going on with the topic.
The current full topic is:
user/feeds/as3935/ where user is my username.
All mqtt setup:
MQTT Host io.adafruit.com
MQTT Port 1883
MQTT User my user name
MQTT Client cjmcu
MQTT Topic user/feeds/as3935/
MQTT Group Topic 1 tasmotas/cmnd/
MQTT Full Topic user/feeds/as3935/
MQTT Fallback Topic cmnd/cjmcu_fb/
MQTT No Retain Disabled
Hope someone can help
With kind regards T.J.
Feed not showing in io adafruit from Tasmota flashed device
- Tseard01
- brubell
- Learn User Page
Re: Feed not showing in io adafruit from Tasmota flashed dev
I have a few ideas, but I do not have a Tasmota to test against:
What happens when you publish to the topic? Can you visit io.adafruit.com/monitor, turn on your tasmota, and look at the monitor page's output?
Drop the group topic. try subscribing to a feed without a group.MQTT Group Topic 1 tasmotas/cmnd/
- Tseard01
The tasmota device sends the qmtt messages with capital letters, the Adafruit io platform only accepts lower case letters.
I get these:
bliksemdetector/SENSOR = {"Time":"2021-05-11T15:48:07","AS3935":{"Event":0,"Distance":0,"Energy":0,"Stage":7}}
I cannot change this.
Tried another broker and then it does work....
I get these:
- brubell
- Learn User Page
If you can not modify the expected payload/message format, I don't think Adafruit IO will work for your use-case with the Tasmota.
- Tseard01
Well, I, have got it running on Adafruit io, at last.
Added the wildcard (#) to the topic.
Now there are several feeds created such as LWT, STATE, INFO1, SENSOR, etc.
When I checked my feeds, I noticed entry points from earlier this month.
Pretty neat, as I can now choose the feed In want!
Next step, get it to show on my weather website,
I'll keep you updated...
- brubell
- Learn User Page
Great, thank you for updating me!
