SSID and Password not known until setup() is run
by JackTheSE on Thu May 20, 2021 8:25 am
Seems like all the Example Programs from the IO library assume that the SSID and password are known before setup() is run. I have a sketch where that is not true, and my work-around is to create my AdafruitIO_WiFi object twice with the same name: once before setup() is called with blank SSID and password, and once again within setup() after the SSID and password are known. While this seems to work OK, it's like I'm defining the same object twice. Is there another way I should be handling this?
JackTheSE
Re: SSID and Password not known until setup() is run
by brubell on Mon May 24, 2021 9:34 am
Could you please post your code? Is this relying on an external library for provisioning the WiFi AP?
brubell
