SSID and Password not known until setup() is run
JackTheSE
Post by JackTheSE »
Seems like all the Example Programs from the IO library assume that the SSID and password are known before setup() is run. I have a sketch where that is not true, and my work-around is to create my AdafruitIO_WiFi object twice with the same name: once before setup() is called with blank SSID and password, and once again within setup() after the SSID and password are known. While this seems to work OK, it's like I'm defining the same object twice. Is there another way I should be handling this?
brubell
Learn User Page
Re: SSID and Password not known until setup() is run
Post by brubell »
Could you please post your code? Is this relying on an external library for provisioning the WiFi AP?
