Trouble posting JSON data
by Foamyguy on Sat May 22, 2021 1:04 pm
I am attempting to follow the instructions from the cookbook here:
https://io.adafruit.com/api/docs/cookbo ... on-strings
The POST does complete successfully, I get a 200 status response. But the resulting feed value does not contain all of the data. It only contains a single one of the keys from the data, not any of the values, and not the other key either.
Here is a screenshot of the resulting feed value:
I am using python requests to post my data:
fake_data = {
  "value": {"sensor-1":22.587,"sensor-2":13.182},
  "lat": 38.1123,
  "lon": -91.2325,
  "ele": 112
resp = requests.post(aio_url, data=fake_data, headers=headers)
print(resp.status_code)
Foamyguy
Re: Trouble posting JSON data
by jwcooper on Mon May 24, 2021 10:36 am
Looks like we may need to update that specific cookbook. It's a bit misleading in that it's teaching about properly encoding JSON for IO, but not using the right endpoints.
If you want to send multiple data endpoints, you can do it via the group or batch functionality:
https://io.adafruit.com/api/docs/#creat ... ta-records
https://io.adafruit.com/api/docs/#create-group-data
Also, if you are trying to save data via IO as JSON itself, the above examples you linked should work, but the data won't be usable within IO, such as in dashboards. Dashboards need the actual data to be saved to each feed to be usable, and not json representations of multiple feed values.
If you try to pull the data down via the api for that feed, are you still seeing only the sensor-2 value?
jwcooper
by Foamyguy on Sat May 29, 2021 12:43 pm
I fetched the data by sending GET request (with AIO key in header) to this URL:
https://io.adafruit.com/api/v2/Foamyguy ... test-post/
In the data that I got it does only have "sensor-2" in the last_value field:
'last_value': 'sensor-2',
In the end I was able to get it working by escaping my multiple data values into a string inside the value filed like this:
fake_data = {
    "value": json.dumps({"sensor-1": 22.587, "sensor-2": 13.182}),
    "lat": 38.1123,
    "lon": -91.2325,
    "ele": 112
Foamyguy
