OSError - Failed SSL handshake
basvdk
Post by basvdk »
I'm running a little script that will send temp/pressure/humidity from my Adafruit Funhouse to Adafruit IO.
After succesfully sending data from anywhere between 15 to 30 minutes the communication will fail with the mentioned error:
OSError: Failed SSL handshake
After rebooting the device communication will continue.
Below the script I'm running:
import board
import time
import wifi
from adafruit_funhouse import FunHouse
import digitalio
#################### FUNCTIONS ####################
def reset_dotstar():
    dots = funhouse.peripherals.dotstars
    dots.brightness = 0.0
    return dots
def connected(client):
    print("Connected to Adafruit IO! Subscribing...")
#################### VARIABLES ####################
RED = 0xFF0000  # (255,0,0)
YELLOW = 0xFFFF00  # (255,255,0)
GREEN = 0x00FF00  # (0,255,0)
#################### Board initialization ####################
# Initialize Funhouse object
funhouse = FunHouse(default_bg=None)
# Create a dots object to config individual leds
dots = reset_dotstar()
# Initialize a new MQTT Client object
print("Setting up network and Adafruit IO connections")
funhouse.network.init_io_mqtt()
funhouse.network.on_mqtt_connect = connected
funhouse.network.mqtt_connect()
# Turn of screen
l = digitalio.DigitalInOut(board.TFT_BACKLIGHT)
l.direction = digitalio.Direction.OUTPUT
l.value = False # turns the display backlight off / True will enable the backlight
# startup timestamp
event_timestamp = time.monotonic()
#################### Running code ####################
while True:
    # Process Adafruit IO messages
    funhouse.network.mqtt_loop()
    # Send sensor data to Adafruit IO every 10 seconds
    if (time.monotonic() - event_timestamp) > 10:
        funhouse.peripherals.led = True
        print("Sending data to adafruit IO!")
        funhouse.network.mqtt_publish("temperature", float(funhouse.peripherals.temperature))
        funhouse.network.mqtt_publish("humidity", float(funhouse.peripherals.relative_humidity))
        funhouse.network.mqtt_publish("pressure", float(funhouse.peripherals.pressure))
        funhouse.peripherals.led = False
    # Use the UP button to turn on/ off the display backlight
    if funhouse.peripherals.button_up:
        if l.value:
            l.value = False
        else:
            l.value = True
    # Color the first dotstar red or green based onn wifi connection
    if wifi.radio.ipv4_address:
        dots[0] = GREEN
        dots.brightness = 0.01
    else:
        print("No network connection!")
        dots[0] = RED
mikeysklar
Re: OSError - Failed SSL handshake
Post by mikeysklar »
How far is your Funhouse from the nearest WiFi device? Does it make a difference if you re-orient the Funhouse so the WiFi chip has line of site to the AP? Obviously a bit of overkill, but just trying to understand if this is a WiFi signal issue.
basvdk
Post by basvdk »
I tested it in several locations, one of which was directly besides the AP. These are Ubiquiti AP's and provice excellent coverage throughout the house.
mikeysklar
@basvdk,
Thank you for confirming we are not losing WiFi signal.
There have been cases on this topic before that should be resolved with the current CircuitPython release.
https://github.com/adafruit/circuitpython/issues/3651
What are you currently running in terms of CircuitPython, bootloader and library bundle on the funhouse? It's quite new so I would be surprised if you are running something earlier than CircuitPython 6.2.0. There is a library bundle drop from 20210525 and a CircuitPython 6.3.0 release candidate you could try to see if it the issue resolves.
https://circuitpython.org/board/adafruit_funhouse/
https://circuitpython.org/libraries
basvdk
Post by basvdk »
I've updated to Circuit Python 6.3.0 RC0
Adafruit CircuitPython 6.3.0-rc.0 on 2021-05-25; Adafruit FunHouse with ESP32S2
Also updated the script to do a ping test if another OSError occurs.
        try:
        except OSError:
            print("Current IP address: %s" % str(wifi.radio.ipv4_address))
            ipv4 = ipaddress.ip_address("8.8.8.8")
            print("Ping google.com: %f ms" % (wifi.radio.ping(ipv4)*1000))
        finally:
Will keep you posted :-)
mikeysklar
Thank you for trying the release candidated CP 6.3.0. Please confirm that you also updated the libraries to be current as well.
basvdk
Post by basvdk »
After the update I had it running for 24 hours without loosing connection, so the connection seems more stable after the upgrade.
I then placed the funhouse further away from the AP. The latency for the connection is higher (as expected) but when the device has a bad connection when trying to send messages to IO the OSError returns. I used a simple ping monitor to see if the device was still connected and I can see it occasionally missing a single ping (time out).
It looks like the connection to IO isn't restored automatically after this, should I do a
in the
except:
block to restore the connection?
brubell
Learn User Page
Post by brubell »
Yep, within the except I'd also write some code to verify that the WiFi connection is still established prior to attempting a MQTT reconnection
Return to “Internet of Things: Adafruit IO and Wippersnapper”
