Hello, I am currently learning Java and am doing a very basic IoT project. Here is my code so far:
https://imgur.com/a/j4i77Yn
When I use the full adafruit Key as my clientID, I get an error saying invalid clientID. For some reason, when I shorten it it seems to bypass that error, but now I get the following error:
Exception in thread "main" Bad user name or password (4)
If anybody could guide me in the right direction it would be much appreciated.
How to access feed using Eclipse Paho (Java)?
- brubell
- Learn User Page
Re: How to access feed using Eclipse Paho (Java)?
Please post your full code in between
tags.
[quote]When I use the full adafruit Key as my clientID, I get an error saying invalid clientID. For some reason, when I shorten it it seems to bypass that error, but now I get the following error:
Exception in thread "main" Bad user name or password (4)[/quote]
Please post the full error output from your compiler or console.
- xavz
public class MQTTest {
public static void main(String args[]) throws MqttException {
System.out.println("Starting Program Test");
final String clientId = "aio_DMEg79mPQXngoY";
//MemoryPersistence persistence = new MemoryPersistence();
MqttClient client = new MqttClient("tcp://io.adafruit.com:1883", clientId);
client.setCallback(new SimpleMqttCallBack());
client.connect();
MqttConnectOptions mqOptions=new MqttConnectOptions();
mqOptions.setCleanSession(true);
client.connect(mqOptions); //connecting to broker
client.subscribe("xavz/feeds/distance"); //subscribing to the topic name test/topic
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28)
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:1053)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:151)
at java.lang.Thread.run(Thread.java:748)
- brubell
- Learn User Page
I don't see your Adafruit IO username being used, only your Adafruit IO key.MqttClient client = new MqttClient("tcp://io.adafruit.com:1883", clientId);
Your Adafruit IO username is your username
Your adafruit io key is your password.
You do not need to specify a client id.
