Hi ,
I received the USER id from a previous lab mate and updated the new user id with my details and also regenerated new key. Now device is not able to transfer data. It
I changed the user id and key in the code however no luck. Kindly help.
---> AT+CAOPEN?
---> AT+CIPCLOSE
---> AT+CMEE=2
<--- OK
---> AT+CMEE?
<--- +CMEE: 2
---> AT+CACID=1
<--- +CME ERROR: operation not allowed
Connection failed
Retrying MQTT connection in 5 seconds...
MQTT connection failed
- brubell
- Learn User Page
Re: MQTT connection failed
What software/libraries are you using to connect to Adafruit IO?
What hardware are you using?
Could you please post your FULL code within
tags?
