Help with Adafruit IO Temperature & Humidity Example
- leoleoleo
I'm having trouble using the "Adafruit IO Temperature & Humidity Example". It always fails to initialize the TCP. The FONA seemed to be working on the FONAtest example, but moving on here it doesn't. Did I maybe set up the APN incorrectly, I am really lost. Thank you so much.
- Attachments
- Serial output
- Screenshot_2021-05-16_183739.png (31.15 KiB) Viewed 463 times
- obray21
Re: Help with Adafruit IO Temperature & Humidity Example
HEY,
This is what I have got for you, u may reinstall it with the help of these procedures and then I think there will be no further issues,
CLICK the VIEW AIO KEY button to retrieve your key.
retrieving your key
A window will pop up with your Adafruit IO. Keep a copy of this in a safe place. We'll need it later.
Image of the AIO key
Creating the Feeds
First, you will need to create a feed called Temperature.
Creating the temperature feed
You will also need to create a feed called Humidity.
Creating the Humidity feed
If you need help getting started with creating feeds on Adafruit IO, check out the Adafruit IO Feed Basics guide.
Adding the Line Chart Block
Add a new Line Chart block to a new or existing dashboard. Make sure you have selected both the Temperature and Humidity feeds as the data sources for the block.
When you reach the block settings, set the Hours of History setting to 24 hours, and name the block whatever you would like.
When you are finished editing the form, click Create Block to add the new block to the dashboard.
Add the new block
If you need help getting started with Dashboards on Adafruit IO, check out the Adafruit IO Dashboard Basics guide.
Next, we will look at wiring the circuit.
Wiring
You will need the following parts for this tutorial:
1x Adafruit IO compatible Feather
1x DH22 temperature & humidity sensor
1x 10k ohm resistor
4x jumper wires
We will need to connect the following pins from the Feather to the resistor and DHT22:
Feather 3V to the pin 1 of the DHT22
Feather 3V to one leg of a 10k ohm resistor, and the other leg of the resistor to the pin 2 of the DHT22
Feather pin 2 to pin 2 of the DHT22
Feather GND to pin 4 of the DHT22
Wiring guide
Next, let's look at the example sketch we will be using.
Arduino Setup
You should go through the setup guides associated with your selected set of hardware, and make sure you have internet connectivity with the device before continuing. The following links will take you to the guides for your selected platform.
Adafruit Feather HUZZAH ESP8266 Setup Guide
You will need to make sure you have at least version 2.4.1 of the Adafruit IO Arduino library installed before continuing.
Library files 1
You will also need to install the Adafruit Unified Sensor library.
Library files 2
As well as the DHT Sensor Library.
Library files 3
For this example, you will need to open the adafruitio_15_temp_humidity example in the Adafruit IO Arduino library.
Next, we will look at the network configuration options in the sketch.
Network Config
To configure the network settings, click on the config.h tab in the sketch. You will need to set your Adafruit IO username in the IO_USERNAME define, and your Adafruit IO key in the IO_KEY define.
WiFi Config
WiFi is enabled by default in config.h so if you are using one of the supported WiFi boards, you will only need to modify the WIFI_SSID and WIFI_PASS options in the config.h tab.
FONA Config
If you wish to use the FONA 32u4 Feather to connect to Adafruit IO, you will need to first comment out the WiFi support in config.h
Comment out the WiFi lines if using FONA
Next, remove the comments from both of the FONA config lines in the FONA section of config.h to enable FONA support.
Uncomment both Fona config lines
Ethernet Config
If you wish to use the Ethernet Wing to connect to Adafruit IO, you will need to first comment out the WiFi support in config.h
Comment out WiFi for Ethernet
Next, remove the comments from both of the Ethernet config lines in the Ethernet section of config.h to enable Ethernet Wing support.
Uncomment both ethernet config lines
Next, we will look at how the example sketch works.
Code
The adafruitio_15_temp_humidity example uses digital pin 2 by default on all boards, and that can be modified if needed by changing the DATA_PIN define.
Copy Code
// pin connected to DH22 data line
#define DATA_PIN 2
The next chunk of code creates an instance of the DHT class, and also sets up feed instances for the temperature and humidity feeds.
Copy Code
// create DHT22 instance
DHT_Unified dht(DATA_PIN, DHT22);
// set up the 'temperature' and 'humidity' feeds
AdafruitIO_Feed *temperature = io.feed("temperature");
AdafruitIO_Feed *humidity = io.feed("humidity");
The setup function initializes the DHT22 sensor, and also connects your feather to Adafruit IO. The code will wait until you have a valid connection to Adafruit IO before continuing with the sketch. If you have any issues connecting, check config.h for any typos in your username or key.
Copy Code
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
// initialize dht22
dht.begin();
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Serial.println(io.statusText());
Next, we have the main loop() function. The first line of the loop function calls io.run(); this line will need to be present at the top of your loop in every sketch. It helps keep your device connected to Adafruit IO, and processes any incoming data.
Copy Code
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
The next chunk of code inside the loop() checks the current DHT22 temperature value, and saves the value in the celsius and fahrenheit variables.
We then print both celsius and fahrenheit to the Arduino Serial Monitor, and save the fahrenheit value to the temperature feed on Adafruit IO.
Copy Code
sensors_event_t event;
dht.temperature().getEvent(&event);
float celsius = event.temperature;
float fahrenheit = (celsius * 1.8) 32;
Serial.print("celsius: ");
Serial.print(celsius);
Serial.println("C");
Serial.print("fahrenheit: ");
Serial.print(fahrenheit);
Serial.println("F");
// save fahrenheit (or celsius) to Adafruit IO
temperature->save(fahrenheit);
If you prefer to log celsius values, you can modify the call to the save() function.
Copy Code
temperature->save(celsius);
The final chunk of the loop() function requests a humidity reading from the DHT22, and prints the value to the Arduino Serial Monitor. We also save the humidity value to the humidity feed on Adafruit IO.
Copy Code
dht.humidity().getEvent(&event);
Serial.print("humidity: ");
Serial.print(event.relative_humidity);
Serial.println("%");
// save humidity to Adafruit IO
humidity->save(event.relative_humidity);
// wait 5 seconds (5000 milliseconds == 5 seconds)
delay(5000);
Upload the sketch to your board, and open the Arduino Serial Monitor. Your board should now connect to Adafruit IO.
Copy Code
Connecting to Adafruit IO....
Adafruit IO connected.
You should now see the temperature and humidity values being sent to Adafruit IO.
Copy Code
celsius: 18.30C
fahrenheit: 64.94F
humidity: 34.90%
celsius: 18.20C
fahrenheit: 64.76F
humidity: 35.40%
Check your dashboard on Adafruit IO, and you should see the line chart update with the changes in temperature and humidity.
Check your Adafruit IO dashboard for updates
Add an OLED
Add an OLED
Now that you've got a graphing weather device using IO, you can add an OLED feather so you can see network status, IP address, and the latest measurements!
Plug the OLED FeatherWing on top of your Feather, and check out our guide to get set up and test it! Once you've verified that the OLED works, you can use this new code. Use the same config.h file from the previous section, just replace the 'main' tab of code:
ATTENTION
Copy Code
// Adafruit IO Temperature & Humidity Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io- ... d-humidity
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016-2017 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Adafruit_SSD1306.h>
// oled display
Adafruit_SSD1306 oled = Adafruit_SSD1306();
#define DATA_PIN 2
oled.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)
oled.display();
while(! Serial);
// initialize dht22
dht.begin();
io.connect();
Serial.print(".");
delay(500);
// we are connected
Serial.println();
// text display tests
oled.setTextSize(1);
oled.setTextColor(WHITE);
io.run();
// print it to the OLED
oled.clearDisplay();
oled.setCursor(0,0);
oled.print("SSID: "); oled.println(WIFI_SSID);
oled.print("IP: "); oled.println(WiFi.localIP());
oled.print("Temp: "); oled.print(fahrenheit,0); oled.print(" *F ");
oled.print("Hum: "); oled.print(event.relative_humidity,0); oled.println(" %");
oled.print("IO Status: ");
aio_status_t aio_status = io.status();
Serial.print("Status: "); Serial.println(aio_status);
switch (aio_status) {
case AIO_IDLE: oled.println("IDLE"); break;
case AIO_DISCONNECTED:
case AIO_NET_DISCONNECTED: oled.println("DISCONNECT"); break;
case AIO_NET_CONNECTED:
case AIO_CONNECTED_INSECURE:
case AIO_CONNECTED: oled.println("CONNECTED"); break;
oled.display();
delay(2000);
MUCH OBLIGED.
retrieving your key
Creating the Feeds
Add the new block
Wiring
1x 10k ohm resistor
4x jumper wires
Wiring guide
Arduino Setup
Library files 1
Library files 2
Library files 3
Network Config
WiFi Config
FONA Config
Ethernet Config
Code
Copy Code
#define DATA_PIN 2
Copy Code
Copy Code
while(! Serial);
// initialize dht22
dht.begin();
io.connect();
Serial.print(".");
delay(500);
// we are connected
Serial.println();
Copy Code
io.run();
Copy Code
Copy Code
Copy Code
delay(5000);
Copy Code
Copy Code
celsius: 18.30C
fahrenheit: 64.94F
humidity: 34.90%
celsius: 18.20C
fahrenheit: 64.76F
humidity: 35.40%
Add an OLED
Add an OLED
ATTENTION
Copy Code
#include "config.h"
#include <DHT.h>
#include <DHT_U.h>
// oled display
#define DATA_PIN 2
oled.display();
while(! Serial);
// initialize dht22
dht.begin();
io.connect();
Serial.print(".");
delay(500);
// we are connected
Serial.println();
io.run();
oled.display();
delay(2000);
MUCH OBLIGED.
