Hi there! I'm currently making a small piano that can use Pure Data on the RPi 3 to generate its own music, and so I had bought the Stereo Speaker bonnet to drive audio. The only problem is that the RPi is convinced that the device is busy (see photos of VLC and Pure Data); I found only when first booting up the RPi with the standard BCM2835 and then switching does the RPi drive the audio (which sounds great, by the way! No issue there).
The intention is that music should start playing once the power is turned on, so I had added a sudo command to a python patch that will call Pure Data in /etc/rc.local, but that wasn't working so I switched it to /etc/profile. Unfortunately, I need the RPi to set up all the right commands on power up, since I won't be controlling the piano, so I need a solution that doesn't require input after power up!
Thank you to anybody can help or offer suggestions, and let me know if you need any more information!
Stereo Bonnet: Device or resource busy.
- buzzelljason
- 2.png (941.88 KiB) Viewed 252 times
- 1.png (617.98 KiB) Viewed 252 times
- buzzelljason
Re: Stereo Bonnet: Device or resource busy.
I also wanted to add that I am aware of a Pure Data bug that requires the DSP on message to be delayed so the audio hardware is set in time, but that doesn't seem to have an immediate effect (it is added into the patch, though!).
I also have a picture of my setup and wiring, for those who are interested in checking that out! Nothing too complex there.
- p2.jpg (747.01 KiB) Viewed 251 times
- p1.jpg (535.48 KiB) Viewed 251 times
- adafruit_support_carter
Just want to make sure the basic hardware is working as expected? It sounds like it is based on your comment here:
Also - that's a really cute little piano build :)
So this seems more like a config (software) issue getting things to work with your setup? Pure Data, etc.I found only when first booting up the RPi with the standard BCM2835 and then switching does the RPi drive the audio (which sounds great, by the way! No issue there).
- buzzelljason
Yes, I believe this is a software issue! On the occasion that the device is not busy, everything works perfectly, even the speaker-test.
- buzzelljason
Hi again! A little update on the bonnet: I'm currently not using it anymore because the issue was random and persistent, so I couldn't guarantee for a fact that it would work every time I powered on the device, no matter what I tried. I'd still like to know though why this issue is happening going into the future, in case I decide to use it for a different project! Thanks!
It seems like this is related to something with Pure Data, which we have no direct experience with. In general, it seems like some other process is claiming the device or it's not configured as needed.
