Delete old feed data
Tom_Henry
Post by Tom_Henry »
I just subscribed to io Plus. Looking forward to converting all my sensor date to dashboards.
Check out this dashboard: https://io.adafruit.com/Tom_Henry/dashboards/bme680
I have been trying to add the feed altitude to this dashboard using a altitude-block icon, and I have done everything the same as I did on the other 3 feeds you see on my dashboard. I can’t get the bar-chart icon to show up. I did exactly the same set up using altitude and altitude-block. I can’t tell how many times I have deleted the blocks and tried again. Any suggestions for me on this?
And my second question: Is there an easy way to delete old feed data from say a temperature feed?
I know that I can delete one feed at a time but that takes forever.
Tom Henry
Tom_Henry
Re: Delete old feed data
Post by Tom_Henry »
Ok I fixed the Altitude problem.
However, sometimes the humidity reading comes out wrong but usually corrects itself within a minute or so.
I still would like to know if I can delete a group a say temperature feeds all at the same time.
Tom Henry
brubell
Learn User Page
Post by brubell »
I'm not sure what "wrong" means in this context? Is the humidity value on the adafruit io different from the value read by the sensor?
You can delete a group of feeds by calling this API endpoint: https://io.adafruit.com/api/docs/#delete-group
