I have created an Adafruit IO desktop using Adafruit’s BME680 sensor and it looks like the attached screen shot.
Now I want to add the Date and Time using Adafruit’s PFC8523.
I have created 2 feeds called date and time that will contain the text fields for the date and time.
Here is the while True: section of my CircuitPython code and the output so far:
while True:
t = rtc.datetime
print()
print("Today is %s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year))
print("The time is %d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec))
print()
print("\nTemperature: %0.2f C" % bme680.temperature)
print("Temperature: %0.2f F" % F)
print("Gas: %d ohm" % bme680.gas)
print("Humidity: %0.2f %%" % bme680.relative_humidity)
print("Pressure: %0.2f hPa" % bme680.pressure)
print("Pressure: %0.2f psi" % psi)
print("Altitude = %0.2f meters" % bme680.altitude)
time.sleep(60)
# publish to adafruit io
io.publish("temperature", F)
# io.publish("gas", bme680.gas)
io.publish("humidity", bme680.relative_humidity)
io.publish("pressure", psi)
io.publish("altitude", bme680.altitude)
Output for the above:
Today is Sunday: 6/26/2021
The time is 20:26:14
Temperature: 28.33 C
Temperature: 80.62 F
Gas: 56887 ohm
Humidity: 41.00 %
Pressure: 1000.76 hPa
Pressure: 14.51 psi
Altitude = 104.54 meters
I need some help on creating a text string for the date and time.
Would appreciate any ideas or suggestions you might have.
Thanks,
Tom Henry
Add Date and Time to my Dashboard
- Tom_Henry
- Attachments
- Date and Time.png (501.79 KiB) Viewed 181 times
- brubell
- Learn User Page
Re: Add Date and Time to my Dashboard
I'd save the print statement:
as a string like:
Then, call io.publish with a new feed for storing the date:
And do the same for time.
todays_date = "%s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year)
io.publish("newDateFeed", todays_date)
- Tom_Henry
Monday
Thank You!
Now my Dashboard is complete with the date and time.
Here is my code:
while True:
t = rtc.datetime
# print(t) # uncomment for debugging
print()
todays_time = "%d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec)
time.sleep(60)
io.publish("date", todays_date)
io.publish("time", todays_time)
Tom Henry
Thank You!
Here is my code:
while True:
t = rtc.datetime
print()
time.sleep(60)
Tom Henry
- Attachments
- Date and Time.png (494.2 KiB) Viewed 165 times
