Add Date and Time to my Dashboard
Tom_Henry
Post by Tom_Henry »
I have created an Adafruit IO desktop using Adafruit’s BME680 sensor and it looks like the attached screen shot.
Now I want to add the Date and Time using Adafruit’s PFC8523.
I have created 2 feeds called date and time that will contain the text fields for the date and time.
Here is the while True: section of my CircuitPython code and the output so far:
while True:
t = rtc.datetime
print()
print("Today is %s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year))
print("The time is %d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec))
print()
print("\nTemperature: %0.2f C" % bme680.temperature)
print("Temperature: %0.2f F" % F)
print("Gas: %d ohm" % bme680.gas)
print("Humidity: %0.2f %%" % bme680.relative_humidity)
print("Pressure: %0.2f hPa" % bme680.pressure)
print("Pressure: %0.2f psi" % psi)
print("Altitude = %0.2f meters" % bme680.altitude)
time.sleep(60)
# publish to adafruit io
io.publish("temperature", F)
# io.publish("gas", bme680.gas)
io.publish("humidity", bme680.relative_humidity)
io.publish("pressure", psi)
io.publish("altitude", bme680.altitude)
Output for the above:
Today is Sunday: 6/26/2021
The time is 20:26:14
Temperature: 28.33 C
Temperature: 80.62 F
Gas: 56887 ohm
Humidity: 41.00 %
Pressure: 1000.76 hPa
Pressure: 14.51 psi
Altitude = 104.54 meters
I need some help on creating a text string for the date and time.
Would appreciate any ideas or suggestions you might have.
Tom Henry
Date and Time.png (501.79 KiB) Viewed 175 times
brubell
Learn User Page
Re: Add Date and Time to my Dashboard
Post by brubell »
I'd save the print statement:
as a string like:
todays_date = "%s: %d/%d/%d" % (days[t.tm_wday], t.tm_mon, t.tm_mday, t.tm_year)
Then, call io.publish with a new feed for storing the date:
io.publish("newDateFeed", todays_date)
And do the same for time.
Tom_Henry
Post by Tom_Henry »
Monday
Thank You!
Now my Dashboard is complete with the date and time.
Here is my code:
while True:
t = rtc.datetime
# print(t) # uncomment for debugging
print()
todays_time = "%d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec)
time.sleep(60)
io.publish("date", todays_date)
io.publish("time", todays_time)
Tom Henry
Date and Time.png (494.2 KiB) Viewed 159 times
