File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0xb5715250>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/cajeck/feeds/pressure/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5715250>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "environmental_monitor.py", line 111, in <module>
aio.send(pressure_feed.key, int(pressure_data))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 154, in send_data
return self.create_data(feed, payload)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 254, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 126, in _post
data=json.dumps(data))
File "/usr/lib/python3/dist-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3/dist-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='io.adafruit.com', port=443): Max retries exceeded with url: /api/v2/cajeck/feeds/pressure/data (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5715250>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
File "environmental_monitor.py", line 62, in <module>
gas_feed = aio.feeds('Gas')
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 274, in feeds
return Feed.from_dict(self._get(path))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 118, in _get
self._handle_error(response)
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 108, in _handle_error
raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found - not found - There is no feed with the key 'Gas'. You can create one using the feed creation API https://io.adafruit.com/api/docs/#create-feed or at https://io.adafruit.com/cajeck/feeds
File "environmental_monitor.py", line 68, in <module>
gas_feed = aio.create_feed(Feed(name='Gas'))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 285, in create_feed
return Feed.from_dict(self._post(path, {"feed": feed._asdict()}))
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 127, in _post
File "/home/pi/.local/lib/python3.7/site-packages/Adafruit_IO/client.py", line 105, in _handle_error
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 400 Bad Request - ['Name must be unique within the selected group', 'Key must be unique within the selected group', 'Group feeds is invalid']
Here's the code for the environmental monitor:
'environmental_monitor.py'
Example of sending I2C sensor data
from multiple sensors to Adafruit IO.
Tutorial Link: https://learn.adafruit.com/adafruit-io-air-quality-monitor
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open source hardware by purchasing
products from Adafruit!
Author(s): Brent Rubell for Adafruit Industries
Copyright (c) 2018 Adafruit Industries
Licensed under the MIT license.
All text above must be included in any redistribution.
Dependencies:
- Adafruit_Blinka (CircuitPython, on Pi.)
(https://github.com/adafruit/Adafruit_Blinka)
- Adafruit_CircuitPython_SGP30.
(https://github.com/adafruit/Adafruit_CircuitPython_SGP30)
- Adafruit_CircuitPython_VEML6070.
(https://github.com/adafruit/Adafruit_CircuitPython_VEML6070)
- Adafruit_CircuitPython_BME280.
(https://github.com/adafruit/Adafruit_CircuitPython_BME280)
CAJECK NOTE:
I'm altering the original code to use the ltr390 for uv, and bme680 for everything else!
# Import standard python modules
import time
# import Adafruit Blinka
import board
import busio
# import CircuitPython sensor libraries
import adafruit_ltr390
import adafruit_bme680
# import Adafruit IO REST client
from Adafruit_IO import Client, Feed, RequestError
# loop timeout, in seconds.
LOOP_DELAY = 10
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = [key]
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username)
ADAFRUIT_IO_USERNAME = [username]
# Create an instance of the REST client
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
try: # if we already have the feeds, assign them.
uv_feed = aio.feeds('UV')
temperature_feed = aio.feeds('Temperature')
humidity_feed = aio.feeds('Humidity')
pressure_feed = aio.feeds('Pressure')
except RequestError: # if we don't, create and assign them.
uv_feed = aio.create_feed(Feed(name='UV'))
temperature_feed = aio.create_feed(Feed(name='Temperature'))
humidity_feed = aio.create_feed(Feed(name='Humidity'))
pressure_feed = aio.create_feed(Feed(name='Pressure'))
# Create busio I2C
i2c = busio.I2C(board.SCL, board.SDA, frequency=100000)
# Create LTR390 object.
ltr = adafruit_ltr390.LTR390(i2c)
# Create BME680 object.
bme680 = adafruit_bme680.Adafruit_BME680_I2C(i2c)
bme680.sea_level_pressure = 1013.25
while True:
print('Reading sensors...')
# Read LTR390.
uv_data = ltr.uvi
# Read BME680.
gas_data = bme680.gas
temp_data = bme680.temperature
# convert temperature (C->F)
temp_data = int(temp_data) * 1.8 + 32
humid_data = bme680.humidity
pressure_data = bme680.pressure
print('sending data to adafruit io...')
# Send BME680 Data to Adafruit IO.
print("Gas: %d ohm" % bme680.gas)
aio.send(gas_feed.key, gas_data)
time.sleep(2)
# Send ltr390 Data to Adafruit IO.
print('UV Index: ', uv_data)
aio.send(uv_feed.key, uv_data)
time.sleep(2)
print('Temperature: %0.1f C' % temp_data)
aio.send(temperature_feed.key, temp_data)
print("Humidity: %0.1f %%" % humid_data)
aio.send(humidity_feed.key, int(humid_data))
time.sleep(2)
print("Pressure: %0.1f hPa" % pressure_data)
# avoid timeout from adafruit io
time.sleep(LOOP_DELAY * 60)
So with this I was able to get it working for a while, as you can see here:
But after that first error, I haven't been able to reconnect. At least, not without losing my feed data. I'd like to see some of this longterm data on a graph, so I want to avoid this. Any help would be appreciated...
