How to fix THROTTLE WARNING?
I have got
THROTTLE WARNING: aaa data rate limit reached, 60 seconds until reset
THROTTLE WARNING
- brubell
- Learn User Page
Re: THROTTLE WARNING
This means you've published too much data in a short period of time, over your account's rate limit. This limit applies to all connections so if you have multiple devices or clients publishing data be sure to delay their updates enough that the total rate is below 2 requests/second.
For more info about how Adafruit IO's MQTT API implements rate limiting, checkout the documentation here: https://io.adafruit.com/api/docs/mqtt.h ... e-limiting
